Epoxy or hot glue ribbon cables?
I messed up the connector to the ribbon cable going to the control buttons on my lilliput.
I jammed the ribbon cable into the slot using some paper to hold it temporarily. I would like to go with a more permanant aproach though.
I am nervous about using epoxy, what if they don't sit quite right, and then don't work? Then I am screwed.
I thought about using hot glue, but will that flow too much and get into the connectors? Or heat up durring use and flow down in?
:: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
