Old 07-27-2005, 04:09 PM   #1
Power_nisse's Avatar
Cool M1-ATX sufficient enough for this setup?
I will connect following
VIA EPIA SP13000, m/Via C3 CPU 1300MHz Mini-ITX,DDR400,VGA,Tv-Out, Firewire
Crucial PC2100 DDR-DIMM 512MB CL2.5. Non-parity, 2.5V, 64Meg x 64
SATA - Samsung SpinPoint M40S 80GB 5400RPM SATA2 2,5" 9,5mm
IDE – Slimline Panasonic DVD ROM/Cd RW 4x
USB - A 7 Avator 7 tft Touchscreen, screen and usb connected
USB - 3COM OFFICECONNECT 11G 108MBPS WIRELESS WLAN
USB - GPS, The gps has batteri but recharges via usb.
USB - Remote controll later on
USB LCD from http://www.crystalfontz.com
According to power calculators its on the edge of wattage.
"maybe" need the "opus 120
solution
Maybe a OPUS 120 will do it! Just have all components in the ampie case and install the OPUS beneath it in a box. Drill holes for the wires etc
Ill go for that solution =) IF the M1 isn`t Sufficient enough.
What do you think?!? =)
Power_nisse is offline   Reply With Quote
Advertisement Sponsored links
Old 07-27-2005, 04:27 PM   #2
You may post new threads
You may post replies
You may post attachments
You may edit your posts
You Might not Delete your post ?!?
"if you asks a power question in a lcs section" Sorry guys
Old 07-28-2005, 03:40 AM   #3
Frankino's Avatar
edit allows you to delete
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Frankino is offline   Reply With Quote
Old 07-28-2005, 04:07 AM   #4
how? i tried to delete all chars and then it said you must have minimum 1 char
Old 07-28-2005, 07:51 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
The option to delete is at the top of the edit page.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
M1 ATX problems Tompa B Power Supplies 30 09-25-2005 07:39 AM
m1 atx 90watt...is it for me? psycos Power Supplies 16 08-13-2005 12:06 PM
Whats happens -> M1 ATX combined power overloaded? Me&you Power Supplies 2 05-09-2005 04:28 PM
Seeking: 300watt, DC to DC, ATX, PS that will take 12 volt input from a Solar setup. Lasivian Power Supplies 15 06-24-2004 10:49 AM
