I just installed mine today, I will provide a detailed writeup in a few days. Here's a sneak peak of the setup:
www.toyotaoffroad.net/afertig/lcdvideo
Pros:
1)Cheap
2)Fully motorized
3)good looking picture so far
4)4 different aspect ratios, wide, zoom, normal, stretch....
4)lots of inputs and one output
5)comes with TV tuner
6)decent remote control
7)you can independently control front l/r and rear l/r individually, and also has a subwoofer level adjustment
8)Cheap
Cons:
1)sticks out of the din opening about 2 inches. Wouldnt fit all the way in my dashboard because there are TONS of wires to stuff behind it.
2)There is a fairly loud hissing noise that is present all of the time, even when the volume is turned all the way down. Ive just emailed support on it and I will see if they can help. Quite annoying. Dont know if I can live with it.
3)I can hear pops and clicks when I have the unit turned on playing something, and open or close the motorized display. Also emailed tech support about this.
Thats all I can think of right now. I havent got much play time out of it, so Im sure ill run into other things, both good and bad. Im working on building a box for my computer and I will have a detailed writeup of everything when Im finished.
