Old 07-29-2005, 01:07 AM   #1
PSOne input question: multi-AV or mini-jack?
I want to hook my PSOne LCD upto my graphics card, but for the time being, I don't want to do a full VGA (actually DVI-I analog, probably) mod.
In practice which input have people found easier to use? The mini-jack on the back, or the multi-AV on the front?
For example:
a) get a mini-jack to composite video cable (does such a cable for s-video exist?)?...then just use a composite out from the graphics card into the mini-jack?
or
b) get a multi-AV cable (I've never seen a female-ended multi-AV...do such exist?) and just use the composite from the graphics card?
Thanks!
Xylo
(P.S., I *am* searching through the forums, but having a hard time really finding what I am trying to figure out.)
Xylo is offline   Reply With Quote
Old 07-29-2005, 01:24 AM   #2
vcbb5's Avatar
If it is an official screen, do the vga hack: http://tidder.rudyatek.com/lcd/
I have never seen av females or anything, and idk if that would work.
composite or s-video would probably not be worth it, as the screen would be unreadble in most situations.
Ps- why do u hesitate to do the vga hack?
My Mazda 3s
My Mazda 3s on Car Domain
[||||||||||||||||||--] (90%)
vcbb5 is offline   Reply With Quote
Old 07-29-2005, 01:31 AM   #3
KyleYankan's Avatar
How good are the PSone's? I'm looking for an affordable screen now and a PSone screen seems pretty nice.
KyleYankan is offline   Reply With Quote
Old 07-29-2005, 01:48 AM   #4
I don't fully understand yet the csync problem, so I don't have a good solution in advance yet...shrug...we'll see.
Old 07-30-2005, 07:10 PM   #5
The official Sony "psone" screen is the same as the "Verge" and "Zenith" gamescreens (Samsung LTS500Q1-GF1). The only difference is that they're missing the "input board" found in the "psone" units. That shouldn't be a problem though since I found a nice wiring diagram at a french site which applies to all of these screens.
TrueWarlord is offline   Reply With Quote
Old 07-30-2005, 07:15 PM   #6
Oh yeah, here a pic of my Zenith with rca inputs added to the side. You could just as easily add s-video, vga, or component.
Old 07-30-2005, 07:22 PM   #7
KyleYankan's Avatar
Hm.... these seem interesting. There not VGA, but there affordable enough... Can anyone give me some input on the quality too? Anything about using this as a main screen?
Old 07-31-2005, 02:00 AM   #9
For example:
or
Thanks!
Xylo
Option A is the way to go, if you're using composite video, as the mult-AV jack uses composite video as the sync signal, and therefore probably wouldn't work. Hmm.. come to think of it, I've never tried doing it that way... I guess I'll experiment later, as I have a Composite+Stereo/Multi-AV cable. You can get a simple adapter to go from S-Video to composite, though you won't get the full quality of S-Video.
tom61 is offline   Reply With Quote
Old 08-12-2005, 09:40 PM   #10
Thanks for the replies...
Now, does anyone know of a S-video to the mini-jack cable or connector?...
Old 08-13-2005, 08:46 PM   #11
You'll need to stack the S-Video to composite and the composite to mini-jack adapter to get what you want, or build your own cable with the needed capacitor in it.
Old 08-14-2005, 09:45 AM   #12
starfox's Avatar
It really annoys me that Sony didn't choose a controller IC that accepts SVideo input... Otherwise you could just use the SVideo signal from your video card and get a good enough image... *sigh
starfox is offline   Reply With Quote
Old 08-14-2005, 10:37 AM   #13
Raw Wave
Rob Withey's Avatar
They did. Check the data sheet for the AN2526 linked from here: http://benheck.com/phpBB/viewtopic.php?p=72847
Page 3, application circuit example 2 show a component taking a luminance and a chroma signal.
In fact, just check that benheck page for how to do the s-video mods. This was previous dicussed on mp3car here : http://www.mp3car.com/vbulletin/lcd-display/56240-s-video-psone-screen-info.html
Rob
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 08-14-2005, 04:57 PM   #14
Oh yeah, I have confirmed that using composite through the multi-A/v jack doesn't work, so you have to use the mini-jack for composite.
Old 08-14-2005, 09:09 PM   #15
starfox's Avatar
In fact, just check that benheck page for how to do the s-video mods. This was previous dicussed on mp3car here : http://www.mp3car.com/vbulletin/showthread.php?t=56240
Rob
cool, thanks for pointing that one out, will give it a shot too
PAC Audio Aux input amp pop question knubile Car Audio 0 05-03-2005 08:28 AM
Question: Need input on 4CH. Amp IntellaWorks Car Audio 12 01-18-2005 09:11 AM
Question for STARFOX or anyone else about PSONE LCDs Phire LCD/Display 16 08-04-2004 03:07 PM
Another PSOne Mod question. Looked but no answer! Learic LCD/Display 5 06-27-2004 02:02 AM
newbi 1st question - mini PC dunkonu General Hardware Discussion 4 12-24-2003 03:55 AM
