Old 08-09-2005, 06:51 AM   #1
mfazi1612 is on a distinguished road
motorized 7 inch vertical eject options
Hi, I'm after a top quality 7 inch, VGA, touchscreen monitor that has a motorized eject mechanism. However, the unit must be programmable so that it just ejects out and doesn't flip back. This is so I can mount it vertically in the dash and have it pop up out of the top.
I've been looking round for ages but haven't come across one that meets all those requirements. Any suggestions would be gratefully appreciated.
mfazi1612 is offline   Reply With Quote
Old 08-09-2005, 07:02 AM   #2
ukchris's Avatar
ukchris is on a distinguished road
I think a screen like my DWW-700M should do it, it remembers where it was last set.
ukchris is offline   Reply With Quote
Old 08-09-2005, 07:49 AM   #3
Thanks for the prompt reply. So it remembers where you last set it. Can you set it to flip 0 degrees after popping out then?
thanks
Old 08-09-2005, 09:44 AM   #4
01 Venom is on a distinguished road
ukchris how do you like the screen? what video card are you using and at what resolution? I am looking at my options for screens
01 Venom is offline   Reply With Quote
Old 08-11-2005, 03:10 PM   #5
ukchris, can it be set to not flip (i.e. at 0 degrees). Thanks
Old 08-12-2005, 11:50 AM   #6
can anyone please provide an answer to this question?
Old 08-12-2005, 11:52 AM   #7
elmo's Avatar
elmo is on a distinguished road
surely with a motorised system there would be a seperate motor for turning the screen to a 90 degree angle, cant you just get in the disable it, it may be as simple as removing a belt, that way you can put it back on if you ever wanted to
www.streetrace.co.uk - The UK's best modified car club (With lots of 16/17/18 year olds for scouse to abuse)
elmo is offline   Reply With Quote
Old 08-12-2005, 12:05 PM   #8
RX8xx is on a distinguished road
The Lilliput 7inch motorized remebers its position so you can set it at 90
and it will go back to that position when it shuts down
RX8xx is offline   Reply With Quote
Old 08-12-2005, 01:32 PM   #9
Its just that when I pay so much for a screen I don't want to have to open it up and have to 'break' it. Also, surely it would be cheaper to find one that just opened and closed automatically but you lifted up manually?
Old 08-12-2005, 01:37 PM   #10
Cravex7's Avatar
Cravex7 is on a distinguished road
Avoid that screen like the plague, you can read about peoples problems with it in the link below but to cut a long story short most of them have broken within days.
http://www.mp3car.com/vbulletin/lcd-display/54684-lilliput-dash-7-a.html
"This bloke said to me you haven't got a clue about the damage the soap bar can do to you,
I tried to see things from his point of view but I couldn't fit my head up his arsehole too."
Cravex7 is offline   Reply With Quote
Old 08-12-2005, 01:54 PM   #11
regal is on a distinguished road
It also remembers its way back to Hong Kong, and it needs too believe me.
regal is offline   Reply With Quote
Old 08-12-2005, 09:10 PM   #12
Question
so does anyone know of a screen that just pops up but doesn't flip back? I'd like it to be motorized as opposed to spring loaded as it should also retract back automatically?
Need help! Motorized in-dash LCD enclosure semester project. RPI Geek Fabrication 29 12-14-2006 10:19 AM
different motorized options already? RoyN LCD/Display 2 04-18-2005 08:27 PM
3/4 inch Plexi Glass/Diamond Plate Amp Box lostreception Fabrication 6 03-20-2005 09:15 PM
build XENARC 7 inch into motorized DIN ? BOND007BE LCD/Display 6 09-23-2003 03:43 PM
