Old 08-10-2005, 09:44 PM   #1
jagsnag is on a distinguished road
xenarc doesn't need regulated power?
it looks like a lot of screens are run from the opus and I was going to as well... but received my xenarc 700tsv and was a little confused when I couldn't find any kind of regulator inline with the cigarette adapter. that's weird so I checked their website and the operating voltage range is 8-14v. a few searches later and it looks like the xenarc700's don't need regulated power externally, they must have some internal regulation!
What's the general concensus using xenarcs? I'm thinking it wouldn't take too much effort to tap a molex on the Opus and run it up where the lcd is BUT.... if it's not needed it sure would be nice to just plug the lcd into the old head unit's power harness.
If you have a xenarc, what did you do? also, I stumbled across a post recommending a type of connector for this powering the lcd from the PSU but can't find it now... any tips?
99 Explorer: Dell Axim X5, Garmin iQue 1620, Dell TrueMobile wifi
97 Venture: MII12k,512M,3.5" 80G,7" Xenarc,Holux GM-210, Keyhole Cam, Scanner + CB --> audio in
currently: installing (finally!)
jagsnag is offline   Reply With Quote
Old 08-10-2005, 10:43 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I plugged mine into the cigarette lighter. It's been powered off of that since January. But I've gotten to thinking that the screen is mighty expensive and ought to be regulated so I'm switching to my power supply during my current install.
I figured why would they give you a cigarette lighter plug if they thought the screen couldn't handle the regulation somehow and that's been the case so far. I just figured better safe than sorry.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 08-10-2005, 10:57 PM   #3
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
and having in mind that that thing that they give you to power the screen is just a cable with a red led....
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 08-10-2005, 11:26 PM   #4
Jcarere is on a distinguished road
Not to mention when your car is running the voltage in the cig lighter is over 14 volts. Mine is around 14.75 volts and my friends are around the same none lower than 14.5 volts. So input voltage is ok with the car off but once you start it the voltage is out of the regulators range.
Jcarere is offline   Reply With Quote
Old 08-11-2005, 07:57 PM   #5
found another spec on xenarc's website - 8-24v. 24v !! ?
Old 08-12-2005, 12:45 AM   #6
Bugbyte's Avatar
I thought I remembered it being higher than 14 volts.
With 24 volts, you're fine in the car but remember that they may be referring to 24 volts continuous power. No telling what may happen if your car's power is dirty or spikey.
Want to:
-Where is the iBug?
Old 08-12-2005, 01:04 AM   #7
Mad Ad's Avatar
Mad Ad is on a distinguished road
why risk not only the cost but the annoyance as well as downtime by running unregulated? They are such a small wattage, youd have to have serious power issues if you couldnt even squeeze a screen in.
Mad Ad is offline   Reply With Quote
Old 08-12-2005, 01:15 AM   #8
Bugbyte's Avatar
Agreed. I did it because the regulator was in the back and the screen was in the front but I'm still nervous. That's why I'm changing it.
Want to:
-Where is the iBug?
Old 08-12-2005, 01:20 AM   #9
TX5
TX5 is on a distinguished road
I have mine plugged into the ciggy lighter. I always intended to run it off the opus, just havnt done it yet.
AMD XP 2000+ 512Mb Ram MB:A-7VM400AM-RZ
Zenarc 700TSV Netgear USB WiFi GPS Opus 150
Running Win XP, FP, MM
TX5 is offline   Reply With Quote
Old 08-12-2005, 03:00 AM   #10
NiN^_^NiN's Avatar
NiN^_^NiN is on a distinguished road
its better to be regulated so the screen won't roll when driving my screen has a roll in it that you don't notice unless you look at it for 5secs.
When your driving faster the screen gets more juice through the system cause of the alternator is outputting more.
It should be fine but is better to be safe and make sure the screen is protected
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 08-12-2005, 12:41 PM   #11
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
cars voltage can be very dirty. your screen cost a few hundred $'s so spend a few bucks to protect it.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 08-12-2005, 12:50 PM   #12
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
The screens are meant to be used on car-power, as it seems, but just to avoid interference, I powered mine from the opus (before I didn't, and it had noise in the picture. A little, but it was there).
I don't think it'll blow, but you just have less other troubles with gear NOT meant to be used in cars (a computer, for example, lol) that's connected.
JC-S60 is offline   Reply With Quote
Old 08-24-2005, 07:00 PM   #13
what kind of connector did you guys use to plug the screen's power wires into the Opus molex connector?
Or did you purchase molex connector sets and crimp onto the screen's wires?
Old 08-24-2005, 07:10 PM   #14
Para Laura
Perhaps a Female molex
Nissan Aux-in MOD
Old 08-24-2005, 07:13 PM   #15
figured so, just wondering if there was a more common connector I could pick up at walmart or something that might fit... one of those bullet connectors or something. I'll check ratshack for some female molex's.. Do you need a special crimper for those?
edited spelling.
Darn ITPS! Need power help! DJ-FrosT Power Supplies 1 07-16-2005 08:40 PM
Xenarc Auto Power On DropTop LCD/Display 10 04-05-2005 01:49 AM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
xenarc won't power on...help joelw23 LCD/Display 14 11-16-2004 11:38 AM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
