Old 06-01-2001, 02:04 AM   #16
Unregistered User
ODYSSEY's Avatar
Post
Quote:
I wrote:
When the AIW is using TV-out to my 5" LCD TV the display has a 1cm border on the bottom after making the display as big as possible under the screen adjustment setting. Is there a way to make the display fill the whole screen or alittle over? I can hook-up four other devices to the display (VCR, TV, Web-Cam, Camcorder) and they all use the whole screen.
Repsonse:
Regarding "When the AIW is using TV-out to my 5" LCD TV the display has a 1cm border on the bottom after making the display as big as possible under the screen adjustment setting."
It may be the way the TV sees the sync signal from our card. If that is the case then there is no known resolution for it.
You may want to try the latest ATI Display driver for your product, perhaps even try The alternative Display Driver for your product.
Really helpful. I'm going to email them back and ask why the tuner software can use the whole display.
Quote:
If your TFT supports PAL input, try to make your video card output PAL.
Tried it. Only would output B/W and same problem. My LCD supports both NTSC and PAL.
ODYSSEY
ODYSSEY
Quote: Originally Posted by Tidder View Post
Digital-Car UK|
(\__/)
(")_(")
ODYSSEY is offline   Reply With Quote
Old 06-06-2001, 08:24 PM   #17
Post
well i went to best buy today and bought a "RAGE FURY PRO" (ati) and it did not fix the problem, do you guys know if the ALL-IN-WONDERŽ 128 pro ($130-150) has "overscan" option?
hthillet is offline   Reply With Quote
Old 06-07-2001, 01:22 AM   #18
Unregistered User
ODYSSEY's Avatar
Post
So far all i know is the file "ATITVO32.dll" has to do with the tv-out settings on ATI cards. Like I stated before my card will only overscan while i'm using their tuner software @ 640x480. Otherwise it is a 1cm border on the top or bottom or a 1/2cm border top and bottom. ATI tech support has been no help at all. They only give me idiot answers like: Install the lastest ATI drivers; Insure the correct monitor driver is installed. Last I knew tv-out didn't need a driver. I'm playing around with powerstrip, but no luck so far. If i could just find out what mode the card is in when I use the tuner software.
ODYSSEY
ODYSSEY
Digital-Car UK|
(\__/)
(")_(")
Old 06-07-2001, 03:45 PM   #19
Post
i have the same problem with my Jaton Trident 77-3d&tv (9750). someone said that there was a file or something that will make it permanently overscan. i have the overscan option, but it will only go into overscan when i manually enable it after every boot. im stuck for ideas.
2004 F-150
Shuttle XPC, 80gig HD, Wireless Internet, DVD
"How piMP3d is your ride??"
RaZor is offline   Reply With Quote
Old 06-07-2001, 06:02 PM   #20
Unregistered User
ODYSSEY's Avatar
Post
I got the registy edit to work. For Rage Pro cards
1) Go to "HLM\software\ATI Technologies\Desktop" Then look for "TVOverscan" change the value to "1"
2) Reboot
3) Open the display properties
4) Click Advanced
5) Click the adjustment tab
6) Select "Televison" for display
7) Click Advanced
8) See the new Overscn option.
Hope it helps.
ODYSSEY
ODYSSEY
Digital-Car UK|
(\__/)
(")_(")
Old 06-08-2001, 05:15 PM   #21
Post
finally!! got it working!! this is how i did it
1) go to start then run, and type REGEDIT
2) find the folder: HKEY_LOCAL_MACHINE\
Software\ATI Technologies\Driver\####\DAL
(#### = version of the driver you are using on your video card)
3)when you get to the "DAL" folder add DWORD "TVEnableOverscan" and change the value to "1"
4) restart your computer
you should have the option now
Note this "hack" should work with the following cards:
ALL-IN-WONDER 128 PRO
ALL-IN-WONDER 128
RAGE FURY PRO
RAGE FURY
RAGE MAGNUM
RAGE 128
RAGE 128 PRO
XPERT 2000 PRO
XPERT 2000
XPERT 128
XPERT 99
Make sure you are using NTSC! i dont think this would work on PAL
GOOD LUCK!!
Old 06-08-2001, 09:31 PM   #22
Post
i tried last night to somehow hack the registry for overscan enabling on my jaton card. i found the spot(s) where it would be, but i dont know which one it is. its not an easy name like the ati one. any help or if someone wants to work on it with me, it would be greatly appreciated! thanks
2004 F-150
Old 06-13-2001, 12:33 AM   #23
Post
Looks like this is a common problem on most video cards.
I've tried a Creative TNT2 Ultra, a Leadtek Geforce2 MX and a ATI AIW Radeon and they all leave a 0.5" border all the way around the screen.
I'm using the Geforce 2 card right now with Detonator 3 drivers from NVidia, so if anyone knows how to overscan this card...help!
Fourgig is offline   Reply With Quote
Old 06-13-2001, 05:10 PM   #24
Post
and to think that i was the only one with this problem...man was i wrong
2004 F-150
Old 06-13-2001, 05:24 PM   #25
Post
try with the asus v7700drivers. i have one of this cards and they can "overscan".
asus drivers
Old 06-13-2001, 06:41 PM   #26
moahdib's Avatar
Post
I have tested 3 video cards. ATI AIW PRO PCI 8MB, Trident 9685 4MB with TV-out (PCI) and the MSI6215 bookPC with TV-OUT ( on intel 815 chipset)
Out of all of them i couldn't get the ATI to stretch and fill my 5.6" LCD but on the trident and the intel chipset I was able to do so. The newest intel chipset is very good by the way, I highly recommend the MSI bookPC.
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Old 06-15-2001, 03:31 AM   #27
Post
Quote:
Out of all of them i couldn't get the ATI to stretch and fill my 5.6" LCD but on the trident and the intel chipset I was able to do so.[/QB]
How? I have the 9785 and i cant get it to boot full screen? Did you just install the drivers and presto, it worked fine?
2004 F-150
Old 08-08-2001, 03:40 PM   #28
Registered User
Red face
Quote:
Originally posted by moahdib:
<STRONG>I have tested 3 video cards. ATI AIW PRO PCI 8MB, Trident 9685 4MB with TV-out (PCI) and the MSI6215 bookPC with TV-OUT ( on intel 815 chipset)
Out of all of them i couldn't get the ATI to stretch and fill my 5.6" LCD but on the trident and the intel chipset I was able to do so. The newest intel chipset is very good by the way, I highly recommend the MSI bookPC.</STRONG>
cant get mine to overscan !!
i have the 6215 too
pls help me out
time for the sig:
'00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
gerard is offline   Reply With Quote
