Old 08-15-2005, 03:53 PM   #1
Zebelkhan's Avatar
Zebelkhan is on a distinguished road
Lilliput turns on without any power.....WTF!
I am not even sure how to search for this so I am not even going to try...
I had never noticed this before, but when I was putting my lilliput back in the car, I plugged the VGA cable first, then plugged the USB looking thing next, and before I had a chance to plug the power cable in, the lilliput turned on.....
Can't figure it out. The monitor seems to somehow get its power from the carputer because it shuts off when carputer is off. The only other thing I have connected on the other end is my backup camera to the Video-1 line. But even that gets power from back-up lights only when ignition is on and car is in reverse. The monitor works fine, with or without the power cord attached....!
I am guessing an internal short in the USB looking thing cable. Anyone else with this "problem"?
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 08-15-2005, 05:14 PM   #2
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
What the heck???
antimatter is offline   Reply With Quote
Old 08-15-2005, 05:36 PM   #3
viguera is on a distinguished road
Now that's strange...
The VGA/TS cables carry no power (or at least not enough to power the screen itself ), so it's gotta be coming in from the cable, since you can power it from there if you use the black power plug that it comes with, so the pins obviously have to be there (and in the connector on the board). Having looked at that damn picture all weekend long from digitalww's site (http://www.digitalww.com/Lilliput_to...ideo_diag.jpg), I can see how a short inside the cable itself is more likely, but I don't know if that connection on top of video 2 is for power... could short out easily if that is since the solder points are so close, I guess.
viguera is offline   Reply With Quote
Old 08-16-2005, 10:00 AM   #4
Enak's Avatar
Enak is on a distinguished road
Further more, the screen's take 12v and USB is 5v....
Weird...
Enak is offline   Reply With Quote
Old 08-16-2005, 11:09 AM   #5
edikp is on a distinguished road
Weird...
Well, that "looks like a USB" port is not actually utilized for a connection that use a USB interface. So I don't think 5V exists there.
However, I agree. It's weird. There's probably 12V on the "USB look like" cable. Have you used your meter to find out?
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
edikp is offline   Reply With Quote
Old 08-16-2005, 11:16 AM   #6
Correct. The "real" USB connection is in the main cable, and it splits to the controller inside the casing. The rca cable that goes to the "pseudo-usb" connector does carry the 12v if you use the AC adapter. A short there could (and obviously does, in this case) power the screen.
Old 08-16-2005, 12:42 PM   #7
Zebelkhan's Avatar
Thanks for all responses. My monitor hooked up as following: Just as if using the AC adaptor, 12-v power from the carputer PSU is fed into the "pseudo-usb" connector cable on the side where the RCA connectors are (but not to the RCAs of course!). Then, the "pseudo-usb" end is plugged in to the monitor. Assuming there is a short in the cable, which makes one of the pins on the "pseudo-usb" connector hot, why would that hot pin power the board? Is there a connection? I have a replacement cable now and I will swap it to see what will happen.
Also, while I was handling the monitor when it was in pieces, I broke one of the little "winding" thingys in the corner marked L101. The wire on it (wihich is as thick as a strand of hair) also broke so I ended up soldering it back (I am so proud of myself!). Now I have lost default language! I programmed the monitor for english as default but some Far-East language shows up that I cannot understand. Otherwise eveything works perfectly. You think these could be related?
Old 08-16-2005, 01:00 PM   #8
Wait... if you have 12V going into the side connector from the PSU, then you're supplying power to the unit, and there's no short... that's the way it's supposed to work.
Old 08-16-2005, 01:02 PM   #9
Zebelkhan's Avatar
But I am not connecting the power cable end on the monitor side! Just the "pseudo-usb" connector...
Old 08-16-2005, 01:08 PM   #10
You're just confusing me now...
Is there power going to that breakout cable or not?
Old 08-16-2005, 01:10 PM   #11
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
is this not a blessing if you don't have to run an extra power cable? lol
tj!2k4 is offline   Reply With Quote
Old 08-16-2005, 01:28 PM   #12
Jesus Freak
antimatter's Avatar
No
he said he just has the USB type connector plugged in not the power
Old 08-16-2005, 01:32 PM   #13
Quote: Originally Posted by antimatter
No
But he said he had power going to the USB type connector...
Old 08-16-2005, 01:36 PM   #14
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
yeah if he has power going to the barrel plug on the cable that has the USB connector then that would be correct that it would power the screen. 1 of those pins in that USB style connector actually just goes into the positive pin of the power connector that is on the mainboard
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 08-16-2005, 01:41 PM   #15
Zebelkhan's Avatar
Okay. The cable looks like this:
On computer end, there are 3 RCA plugs (for Video-1, 2, and audio), plus a connector to plug to the AC adaptor (or PSU).
On the monitor end, there is the USB looking thing (connected) AND the other end of the power cable (not connected).
So I have 12v even if I am not plugging in the power connector on the monitor end. Not only that, but that 12v coming in is somehow getting routed correctly to turn on the monitor!
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 08:45 AM
power for the Lilliput Paradigm_Guy LCD/Display 13 01-03-2005 10:51 PM
Lilliput Power Source veetid LCD/Display 3 06-27-2004 03:07 AM
Using Lilliput Egg to power HDD alvins Power Supplies 6 05-03-2004 10:44 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
