Old 08-16-2005, 05:53 AM   #1
djmickyg's Avatar
djmickyg is on a distinguished road
touch screen not going to the edge
my 2005 lilliput is acting wierd
i think i am pinching the right side and its wont allow me to touch any further than about 1cm from the right side of the sceen..
has anoyone had this problem?
can over heating screw these things up?
djmickyg is offline   Reply With Quote
Old 08-16-2005, 06:40 AM   #2
my nizzle
shizzle's Avatar
shizzle is on a distinguished road
Have you tried using the calibration program? I have definitely heard of others with similar experiences, but I never had this problem. I also NEVER had to calibrate, so sounds like bad news...
Good luck.
Carputer status: [-*---------]
Im thinking laptop...
shizzle is offline   Reply With Quote
Old 08-16-2005, 07:01 AM   #3
djmickyg's Avatar
yeah i have tried calibrating many times.. but it doesnt do anything..
this is what it sorta looks like
the right hand side goes in even when im pressign the edge of the screen.. more so towards the center
(sorry for the dodge pic.. but u'll get the picture.)
Old 08-16-2005, 07:12 AM   #4
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
Yup you have a bad touch overlay, that is the normal problem that happens to them.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 08-16-2005, 07:14 AM   #5
djmickyg's Avatar
grrrr whats this caused by? to much pressure ont he screen edge or oever heat ??
is it easy to change??
Old 08-16-2005, 07:18 AM   #6
MySQL Error
jcdillin's Avatar
Actually I think it's combination of UV and heat that causes the plastic to separate from the glass substrate. I hear that the newer touch overlays don't have this problem. Other than that I dont know, I have had the same touch overlay now for the last 2 years so maybe it was just a huge batch of bad ones.
Yes it's very easy to change, all you do is cut the tape holding the old overlay on, then tape on the new one.
肚子笑痛了
S60 Install
Old 08-16-2005, 07:22 AM   #7
djmickyg's Avatar
what do u mean by new ? my screens only been used for less than a month
or u mean new. as in the replace ones u can buy??
Old 08-16-2005, 07:31 AM   #8
MySQL Error
jcdillin's Avatar
Wow, so I guess the newer ones still have the problem, that sucks. Maybe send a e-mail to the person you purchased it from, maybe they can get you a new touch overlay under warranty
肚子笑痛了
S60 Install
Old 08-16-2005, 07:46 AM   #9
my nizzle
shizzle's Avatar
Yeah, that isn't right.... that's a defect.
Old 08-16-2005, 07:59 AM   #10
djmickyg's Avatar
i'll try emailing back
Old 08-16-2005, 09:00 AM   #11
djmickyg's Avatar
after doing some searching.. seems like alot of people have this issue
might have to put some sorta fan on the back when i get it all sorted again
Old 08-16-2005, 09:10 AM   #12
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
easy solution!!!! when you calibrate do the most point cal & touch all the edge dots more to the center of the screen... you can change how the touchscreen reacts through calibration..... you don't HAVE to touch right were the dot is..... play with this to see what I mean..... been doing this for a long time, when it's set right it works good enough that you can touch the very edge.... I use a hidden start bar & can even bring that up with a touch
you can compensate for inacuracys in touch this way....try it , it works...
turbocad6 is offline   Reply With Quote
Old 08-17-2005, 04:05 AM   #13
djmickyg's Avatar
turbocad6 - it wont work.. ive tried
ive spoken to the guy i bought it from
he has a years warrenty on the screen..
so im sending it back and he is fixing it..
nice
Old 08-17-2005, 06:16 PM   #14
turbocad6's Avatar
sorry to hear that djm... I thought for sure that would do it... i had this problem with a few lilli's but I never had one that wouldn't work after I played with the calibration... good luck with it when you get it back...
Old 08-18-2005, 02:56 AM   #15
djmickyg's Avatar
or maybe i just havent done it right..
but im getting it replaced anyways so no need to bother with that
need better touch screen drivers Ragle WinNT Based 0 06-27-2005 10:51 AM
Help in identifying a TFT LCD Touch Screen Airport bum LCD/Display 1 06-09-2005 06:20 AM
Need touch screen advice sciff5 LCD/Display 0 05-29-2005 10:58 PM
7” Lilliput touch screen is too dim M pro LCD/Display 7 04-29-2005 02:21 PM
Wide Screen format touch screen belezeebub LCD/Display 1 03-22-2005 11:35 PM
