The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 08-17-2005, 11:44 PM   #1
My Photos: (0)
help with install
I need to install my 7 inch tview touchscreen to my civic. I do not know where to run the 12v wire to. Does anyone have a diagram or pictures on how to run the wires so that when i turn on my car my monitor turns on. anything will be very helpful thanks.
BIGMO is offline   Reply With Quote
Sponsored Links
Old 08-18-2005, 08:05 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
1) Quit reposting the same question over & over again.
2) The reason you reposted the same question is because you didn't get an answer. Why didn't anyone give you an answer? Because this has been covered in the LCD forum over and over again.
3) Did you get a manual with your TView? Did you read it?
4) Did you attempt to contact the manufacturer for assistance?
5) Did you search these forums for a related keyword (perhaps TVIEW as a keyword would yield some useful results)?
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-18-2005, 09:14 AM   #3
MaleBuffy's Avatar
Vehicle: Peugeot 307 CC
My Photos: (0)
LOL, Darquy...why are you posting the same answer over and over again. This has been already covered!
MaleBuffy is offline   Reply With Quote
Old 08-18-2005, 09:27 AM   #4
My Photos: (26)
So that the n00b will at least know what he/she needs to do to locate his answer.
Call it a shove in the right direction.
My Worklog
Old 08-18-2005, 10:41 AM   #5
Vehicle: BMW Z3 Roadster 2.8
My Photos: (0)
Yep find someone who’s not stuck up his own rear end.
I will help you out on this on M8, even though you might be in the wrong place.
After all, if your going to find the time to type it might as well be constructive.
Get yourself a cheap multi-meter, and set it to DC, expose your ignition switch so you can see the wiring, with your meter turned on put the black to ground (earth) now test the wires with the red end and find a wire that gives you a 12v reading only when the ignition switch is turned on. When you find it, connect your switched live from the screen to it.
Hope this helps
regal is offline   Reply With Quote
Old 08-18-2005, 12:52 PM   #6
My Photos: (26)
And telling someone to RTFM isn't constructive?
I think it's far more constructive than giving someone a step-by-step procedure.
Let people learn for themselves. They become more educated.
My Worklog
Old 08-18-2005, 12:57 PM   #7
MaleBuffy's Avatar
My Photos: (0)
I dont think he will find the info Regal mentioned in any monitor Manual, however you are both right, stop this. BIGMO has his info, will probably ask a stupid question again, DarquePV will probably repost himself and someone kind enough will answer the stupid question asked by BIGMO or any other noob. Thats life...live with it!
P.S. What colour (or color, depends on where you live) is the standart 12v line of a car?
Old 08-20-2005, 12:39 AM   #8
shiboilee309's Avatar
Vehicle: 1997 Honda Civic EX
My Photos: (0)
just hook the screen up to your ignition switch. i mean the for the power to the ignition so whenever u urn on the ignition on it will just automatic power up ur screen.
shiboilee309 is offline   Reply With Quote
Old 08-20-2005, 12:41 AM   #9
My Photos: (0)
just hook the power wire to your ignition switch.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
XC90 Install - am I the first?? klokman Worklogs 7 02-13-2007 12:12 AM
94 Jeep Grand Cherokee Install jamiewhittingha Show off your project 10 08-02-2006 01:02 PM
Phase 2 Peugeot 306 Install 306carputer Worklogs 24 02-10-2006 08:00 AM
2002 Montero Limited Install... Squid Show off your project 33 09-22-2005 11:29 PM
How should i install this? jnusaira General MP3Car Discussion 8 08-13-2004 03:03 PM
Sponsored Links
Ad Management by RedTyger
