Quote: Originally Posted by DarquePervert
So that the n00b will at least know what he/she needs to do to locate his answer.
Call it a shove in the right direction.
Yep find someone who’s not stuck up his own rear end.
I will help you out on this on M8, even though you might be in the wrong place.
After all, if your going to find the time to type it might as well be constructive.
Get yourself a cheap multi-meter, and set it to DC, expose your ignition switch so you can see the wiring, with your meter turned on put the black to ground (earth) now test the wires with the red end and find a wire that gives you a 12v reading only when the ignition switch is turned on. When you find it, connect your switched live from the screen to it.
Hope this helps
