Old 08-18-2005, 10:49 PM   #1
carfreak01's Avatar
Messed up VGA/USB cable
I had my lilliput working fine. The cable did not reach to the passenger seat so I went out and bought a VGA extension cable and a regular 10ft USB cable. I connected the vga and worked fine. Now for the Usb cable, I spliced the original usb/vga cable to connect the extension usb cable. Wired the cables, red,white,black,yellow. Then I connected the usb cable back to the pc and now windows said it did not recognize the device. Sometimes, one in out of 30 tries I got it to recognize. But failed to install. Now I rewired back the original usb plug and it is the same. Have any of you guys spliced the cables to extend them? If so did you have any problems?
carfreak01 is offline   Reply With Quote
Old 08-18-2005, 11:56 PM   #2
I know it doesn't help now, but you should have bought a bone fide USB extension cable (female to male) and used that instead. It keeps you from hacking the original cable (which obviously didn't work) and makes everything much easier to uninstall if you need to move anything...
Regardless, you can get a replacement USB/VGA cable from Armen for $15, so I'd say just go that route and get an extension for the USB and avoid the hassle.
viguera is offline   Reply With Quote
Old 08-19-2005, 12:37 AM   #3
Craigus's Avatar
The max cable length recommended between a USB computer and USB interface is 5 meters. Longer runs can be achieved thru the use of POWERED USB HUBS. not your problem is it?
Craigus is offline   Reply With Quote
Old 08-19-2005, 10:37 AM   #4
MySQL Error
Scouse Monkey's Avatar
yeah i suspect you have a bad connection that is effectively taking you over the 5m limit. I would get a new USB connector and solder it to where you cut the cable and then connect a USB extension.
good luck
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 08-19-2005, 11:12 AM   #5
carfreak01's Avatar
Thanks guys but I have already wired back the original usb plug and one out of a million tries it works. Ive even tried to twist the wires how they are originally. I know i should of bought a female male extension but i wanted to have my carpc finished.. Anyone of you have hacked (spliced) the wires before?
Old 08-19-2005, 11:14 AM   #6
MySQL Error
you could open up your screen and solder a new lead direct to the controller. but be careful. Splicing the wires should not mess it up as one of the xenarc mods is to do that to get it powered off the PC not the screen.
Old 08-19-2005, 11:52 AM   #7
carfreak01's Avatar
Im gonna keep trying, if anyone has this vga/usb cable let me know I need it to be shipped overnight so I can get it tomorrow. This is my first time building a carpc and im struggling
Old 08-19-2005, 06:09 PM   #8
carfreak01's Avatar
Ok now I tried connecting directly the usb extension cable directly to the lilli board and still doesnt work
Old 08-19-2005, 06:53 PM   #9
MySQL Error
you sure you got the pinout right?
Old 08-19-2005, 06:56 PM   #10
carfreak01's Avatar
well i didnt completely removed the 4 wires,I just spliced a little of each of the four and connected the usb plug that i had
Old 08-19-2005, 07:02 PM   #11
MySQL Error
hmmm
odd. Did you try soldering a brand new USB lead?
Old 08-19-2005, 07:06 PM   #12
carfreak01's Avatar
No I didnt solder a new lead yet.. I had this working perfectly until i spliced the original cable?!? Maybe If i get a new vga/usb cable?
Old 08-19-2005, 07:08 PM   #13
MySQL Error
if you have not touched any part of the lead from the screen then just go buy a new lead and use the 9 pin DIN extension from the mp3car store or use USB and VGA extensions. Dont cut anything unless you have to.
WTB: Touchscreen VGA/USB cable carfreak01 Classified Archive 4 08-22-2005 04:18 PM
Longer Lilliput VGA/USB cable? NaFooEsi LCD/Display 4 04-26-2005 03:50 PM
Replacement Lilliput VGA/USB cable CCristo LCD/Display 5 03-25-2005 04:46 PM
WTB: Lilliput vga/usb touchscreen cable tczbu Classified Archive 0 01-24-2005 04:07 AM
FS: Working VGA 7" Touch Lilliput, VGA/USB CAble SEVERED - $140 OBO shipped! jusatry Classified Archive 6 12-21-2004 03:47 PM
