08-21-2005, 05:52 PM
#1
No signal to LCD
hey guy i got a problem with my M10000 it seem like im keeping on getting no signal to my screen, any soluation will be needed..
08-21-2005, 06:03 PM
#2
Um can you please give us som more info. Is there power to your LCD? Check your bios....
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
08-21-2005, 06:11 PM
#3
the LCD is power on, it keep on saying no signa, how can i check the bios?
moptherboard
hard drive
memory chip
powe supply
CD ROM
LCD
what else am i missing? i want just a basic computer that will be able to play MP3 and watch DVD that all. Thanks
08-21-2005, 06:15 PM
#4
DOes the mother board beep at all? Check you ram make sure it fitted in correctly and also make sure you have the correct ram for the mobo, what kind of mobo?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
08-21-2005, 06:19 PM
#5
Old setup Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
08-21-2005, 06:20 PM
#6
Diddnt catch that...U got an M10K
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
08-21-2005, 06:49 PM
#7
for the LCD im using RCA to RCA, do i to set the jump to RCA or something, and what a mobo? m new to this stuff.
08-21-2005, 06:52 PM
#8
MOBO = MOTHERBOARD
ANd that is the exact reason why you are not getting a signal to you LCD, what kind LCD is it? Look in the manual and set the jumper to the appropriate one for RCA.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
08-21-2005, 06:56 PM
#9
In the manual on page 2-19 put the jumper on pins 3 and 4
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
08-28-2005, 05:43 AM
#10
jumper have been set to 3-4 but still no signal, i try going from S-video to RCA, but still nothing, i also trying going from VGA to RCA, but still no signal, i guess the last thing i can really do now is try it on my house monitar, if that doesnt work than i guess it the motherboard.
M 10000
265 mb
120gb hd
DVD/CD-RW
automotive power supply 90v
got any other idea with this problem??
thanks
08-28-2005, 05:45 AM
#11
hey cheekz185
is your computer working though, what are you part are you using for you computer???
08-28-2005, 12:18 PM
#12
Admin. Don't bug or I'll byte.
Hook the PC up to a regular CRT using the VGA cable. Then check in the BIOS on boot up for the video setting. There is a setting in there that allows you to select TV as an output.
| Thread Tools |
| Display Modes |
Linear Mode
