Old 08-25-2005, 08:27 AM   #1
xport's Avatar
Lilliput went dark.
Okay, have had a dual lilliput running in my car for at least 9 months now.
Both are powered directly from the pc 12v line.
Today the back LCD went really dim. I can still see everything including the monitors OSD when I am really close, but its really too dim to watch anything on. Nothing odd happened, actually my son was just watching Baby Einstein movies as he does each morning on the way to the nanny's house.
I tried the auto gain and auto settings, brightness and contrast are at 100.
Like I said the colors and all seem ok, its just really really dim. The OSD for input (VGA, VIDEO1, etc.) are dim as well. I checked the power connection and the vga connections and both are solid. (front lcd is working great).
Anyone have any ideas?
Thanks in advance.
xport is offline   Reply With Quote
Old 08-25-2005, 08:51 AM   #2
MySQL Error
jcdillin's Avatar
sounds like you either lost the inverter or the CCFL tube in the LCD, is the screen still under warranty?
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 08-25-2005, 09:22 AM   #3
Confusion Master
Enforcer's Avatar
Yep , sounds like the backlite or the inverter inside which powers it.
Enforcer is online now   Reply With Quote
Old 08-25-2005, 10:21 AM   #4
Curiosity's Avatar
I think you wouldn't be able to see anything without the backlight. Can you see any white light in the vents on the back?
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 08-25-2005, 10:49 AM   #5
Confusion Master
Enforcer's Avatar
Yes you can.
Just.
Old 08-25-2005, 11:06 AM   #6
I had a simular problem for the first time yesterday.
The screen went darker and darker, and after a few minutes it was completle black.
The touchscreen was still working, but a black screen.
Today a tried again, an the problem was gone, I hope it stays this way :-)
hakira007 is offline   Reply With Quote
Old 08-25-2005, 12:09 PM   #7
xport's Avatar
Im going to run out now and give it a shot, ill check the back for white lites.
Old 08-25-2005, 12:24 PM   #8
xport's Avatar
Okay screen came on right away now, and I left it one while i calibrated and played a few minutes of video. Back to normal. However, there is a slight "burning plastic" smell coming from the vent grates on the back, real slight barely noticable. Two questions since this screen sits two feet from my sons face. Can these overheat, and if so could they ever get hot enough to catch anything on fire?
Old 08-25-2005, 02:40 PM   #9
Curiosity's Avatar
Burning smell, going dim? There's probably something burning out. If it was still under warranty, I'd say set on concrete and leave it powered for a week. I think it would blow a fuse before catching anything on fire though. If you saw any light (you would probably have to be in the dark to see it) then you'll know if it's the backlight next time it goes dim.
Old 08-25-2005, 03:09 PM   #10
xport's Avatar
Okay, it's got a one year warranty, and i bought it on Dec. 1, 2004.
Im just worried it will spark and catch something, so there are fuses in there to stop that from happening?
Old 08-25-2005, 09:07 PM   #11
Curiosity's Avatar
Well, a fuse blows when it draws too much current. Not sure if it could still catch on fire. It could just be that something spilled in it or an insect crawled in around the high voltage inverter and fried.
Old 08-29-2005, 08:04 AM   #12
xport's Avatar
Yeah its toast now. No power light no nothing.
Time to contact the seller.
Old 05-20-2006, 06:57 PM   #13
Moneyfink's Avatar
Mine went dim, so i unplugged it, touchscreen is in place still so i just use the buttons without seeing them. When i enter the menus on the lilly, they arte perfectly bright, only the input from the pc goes dark, i think im gonna try to use a friends laptop and see if its output is dark too
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline   Reply With Quote
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 123 11-06-2008 07:05 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Lilliput TFT touchscreen too dark microwaveman LCD/Display 4 05-17-2005 08:00 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
