The MP3car.com Store
Thread Tools Display Modes
Old 08-06-2001, 11:03 AM   #1
My Photos: (0)
Post "Detachable" displays
I'm looking for examples/advice on creating a TFT display (5-8") that can be stowed and attached to the dash somewhere, only when in use.
It would need to be thin, and ideally housed in some sexy-looking case.
It would require a longer than normal cable so that it can reach the dash.
I was thinking that it could be sweet to have this thing in my console most of the time. if I want to change a song/playlist, I could just open the console, make the change and put it back. if I want to make a lot of changes or use the navigation system, I could just attach it to the dash (magnet or velcro) and have the wire run from the console.
Does anyone see any major problems in doing this? Has this been done already? If you know of any pictures out there, please let me know. I would like to see some examples.
thx.
tbone is offline   Reply With Quote
Sponsored Links
Old 08-06-2001, 11:56 AM   #2
My Photos: (0)
Post
Woohoo! A sexy case, glue some pink lace on it and go to town!
Otherwise you're looking at 1 1/2" deep in the housing for most LCD's. The one I got recently is a Power Acoustik 5.6", and it has a nice case +controls on it.
Mounting wise, it's best to go with a good velcro, as magnets may mess with it. Otherwise then that, you're looking at an RCA line + power that has to run to it, but there should be no problems in a "temp" mount as needed install..
Scott--
97 Firebird Formula Convertable - Project R/T
Project R/T SoundDomain Page
DarkWolf is offline   Reply With Quote
Old 08-06-2001, 04:44 PM   #3
My Photos: (0)
Post
Just to be clear, by housing, I'm referring to just the part the protects the TFT Screen, similar to the upper half of a laptop (only smaller). Is that what you're talking about? I looked at the power acoustik stuff. All the pictures show the flip-down style. An inch and a half sounds kind of thick. Effectively, I want to end up with a thin small "tablet-like" display.
Old 08-06-2001, 04:57 PM   #4
My Photos: (0)
Post
Oops... my bad, this is the one I got just about, but without the headrest install bezel..
5.6"TFT/LCD 4:3 Ratio
Single Video Input
Headrest Clam Shell Kit
Resolution 960 x 234
NTSC Operating System
Stand Including
Dimensions: 4.5" x 6.5" x 1.5" (x 1" without the black headrest bezel)
Most LCD "Modules" are around .5" deep, but you really do need something to house them in. They're deeper then you would expect because the control board is mounted directly to the screen. With a little bit of hacking and alot of work though you may be able to seperate the screen from the board without trashing it. Though I would not recommend trying unless you feel it's ok to risk $199 or so to get a total depth of .5" with housing.
Scott--
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
