07-14-2001, 04:56 AM
#1
Specific wiring schematic 4 Optrex DMC40457?
I purchased a 40X4 LCD from Amtrex.com.au and wired it up according to the 40X4 LCD wiring diagram going around. I connected it to a powers source and nothing. The only thing that showed up was the backlight. I've gone over it a million times and cannot find a problem with my wiring. I'm wondering if the wiring diagram im using is incorrect. Because the wiring diagram and my data sheet do not line-up, i feel like i've been guessing the pin layouts for connecting it to the parallel port. My question is, Is the standard wiring diagram correct for my LCD, and has anyone else had this problem with regards to using a standard wiring diagram and having to re-arrange the pins? Do i need to use a specific wiring diagram for the Optrex DMC40457?
07-14-2001, 12:35 PM
#2
Hi MP3MAN,
Send me an e-mail of your wiring diagram, the pinout of the display, and the data sheet, and I'll see if I can help you!
Mikep56
07-14-2001, 12:36 PM
#3
Hi MP3MAN,
By the way it is mikep56@earthlink.net. That would probably help!
Mike
07-14-2001, 12:50 PM
#4
You sure your pentiometer isn't just set all the way down?
That was my problem.
95 Honda Civic DX Coupe - In Progress
mp3civic site
07-14-2001, 09:11 PM
#5
thanks mikep56. ill send you the wiring diagram i have and the data sheet with pin layout of my LCD.
and no, the problem is not the potentiometers
07-15-2001, 12:26 AM
#6
Live and Kickin'
Some 4x40's require -5V for contrast, so, um, yea. Check that in the datasheet. Do you have a link to the datasheet, or can you send it to me?
07-15-2001, 01:57 PM
#7
Hi MP3MAN,
I got your e-mail, but when I try to open the data sheet, Acrobat says that there is an error. Please either resend the data sheet or just list all the pins and their functions.
mike
07-15-2001, 04:33 PM
#8
Registered User
Quote:
Originally posted by mikep56:
<STRONG>Hi MP3MAN,
mike</STRONG>
I had the same problem woth Acrobat. Just right-click above the document and select Save As. Then save it do your drive and run it. It will work.
mpt
07-16-2001, 02:48 AM
#9
1 - DB7
2 - DB6
3 - DB5
4 - DB4
5 - DB3
6 - DB2
7 - DB1
8 - DB0
9 - E1
10- R/W
11- RS
12- Vee
13- Vss
14- Vcc
15- E2
16- NC
17- Kathode
18- Anode
These are the pins. I know they are all there, its just I cant figure out which pins go to where. On the wiring schematic for a 40X4, all these pins are listed, and they are wired accordingly. But i still cant work out why it wont work!!
And seeing as how this will be the final touches on my mp3 car, i cant wait to get it to work, hence my desperation.
07-17-2001, 03:11 AM
#10
I've heard that the length of cable used can be a factor....should i try it with a smaller cable first?
| Thread Tools |
| Display Modes |
Linear Mode
