Old 09-06-2005, 05:16 PM   #1
Powerstrip and Lilliput @ 800x480
I know this topic has probably been beaten to death, but can some of you share your powerstrip timing settings? My text @ 800x480 seems a bit fuzzy. Other than that, it looks pretty good. Thanks.
BikeBoy24 is offline   Reply With Quote
Old 09-06-2005, 05:30 PM   #2
Para Laura
thanatos106's Avatar
What video card are you using??
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 09-06-2005, 05:51 PM   #3
Ati Radeon 7000
Old 09-06-2005, 05:55 PM   #4
Para Laura
post 7 and 8 (and I know that there are more in that thread but I let you do the search yourself if the ones in those post don't work )
http://www.mp3car.com/vbulletin/show...ight=quest+800
Thanatos.
Nissan Aux-in MOD
Old 09-06-2005, 09:15 PM   #5
There are no timings on posts 7 and 8.
So I've been fiddling around with the timings, and no matter what I do, I can't get the screen to recognize it as 800x480. Not only that, the text seems a bit blurred. I'm pretty sure the image can be much clearer.
Old 09-06-2005, 09:18 PM   #6
AWDNUT's Avatar
This should be a sticky:
That's from Xenarc, and apparently all the clones use the same thing??
AWDNUT is offline   Reply With Quote
Old 09-06-2005, 09:31 PM   #7
Para Laura
This is no a timing??:
Quote: Originally Posted by redmage
My advanced timings and photos:
-- HORIZONTAL --
Front Porch: 32
Back Porch: 112
Sync Polarity: -
Sync Width: 80
Scan Rate: 37.65 kHz ( Can't be changed )
-- VERTICAL --
Front Porch: 61
Back Porch: 78
Sync Polarity: +
Sunc Width: 3
Refresh Rate: 60.524 HZ
Pixel Clock: 38.55
And this one is no a timing either right??:
Quote: Originally Posted by PatO
Wholy *****! It WORKED! 800x480! I'm using an ATI Radeon X800 (Powercolor) with the display hooked up as secondary. Using PowerStrip.
-- HORIZONTAL --
Front Porch: 32
Back Porch: 112
Sync Polarity: -
Sync Width: 80
Scan Rate: 37.646 kHz ( Can't be changed )
-- VERTICAL --
Front Porch: 61
Back Porch: 78
Sync Polarity: -
Sunc Width: 3
Pixel Clock: 38.550.
All this for "quest for 800x480 thread".... so next time read better
Thanatos.
Nissan Aux-in MOD
Old 09-06-2005, 09:36 PM   #8
Yeah, I saw those. I tried them too. I got "over range"
They're for the xenarc screens
Old 09-06-2005, 09:41 PM   #9
Para Laura
Ohh that is a whole diferent story!!.
And if you read the whole thread like I did you will find out that because you moding the timings with powerstrip those that work with xenarc will work with the lilli.(that is why I say keep looking in that thread).
Thanatos.
Nissan Aux-in MOD
Old 09-07-2005, 12:03 AM   #10
AWDNUT's Avatar
I just tried this on my laptop (Intel GME) and all the little spinners would adjust *except* the active vertical lines (the most important one), it is stuck at 600 (as in 800x600).. That's just a limit of the driver?
Old 09-07-2005, 03:23 AM   #11
Jesus Freak
antimatter's Avatar
stop being an ars thanatos.... you need to read the threads title if anyone needs to read anything. This felow was asking about something that doesn't exist yet... lilliput and correct timings.
THe correct custom timings for the lilliput don't exist and no... just cause they work for the xenarc doesn't mean they work with lilliput
antimatter is offline   Reply With Quote
Old 09-07-2005, 08:36 AM   #12
Of Ice and Men
LagunaICE's Avatar
People tend to chose dogs that match them (personality or even look). I see it works for thanatos.
LagunaICE is offline   Reply With Quote
Old 09-07-2005, 10:13 AM   #13
AWDNUT's Avatar
So back to the topic of timings (in the guys defence it says in the thread that the xenarc timing should work on lilliput).. Any idea of if my problem is with the video card or am I just clueless?
Old 09-07-2005, 10:58 AM   #14
MySQL Error
MatrixPC's Avatar
I don't use PowerStrip on the Lilliput cuz nVidia driver allows custom resolution. The result is much worst compare to 848x480.
You can follow Xernac step/procedure to make it works for the Lilliput but you need to play harder with the setting. They won't be exactly the same setting for the Lilliput and Xernac.
If you can't change it in PowerStrip, it is more likely that the video card doesn't support what you are looking for.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 09-07-2005, 12:59 PM   #15
Jesus Freak
antimatter's Avatar
the point is that the settings provided for the xenarc don't work for the lilliput. If they do show me prove that they do.
Nothing against thanatos he is usually very helpful... just a little short tempered
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Dell laptop, lilliput screen, and 800x480 resolution, possible? sivart321 LCD/Display 3 03-11-2005 11:46 AM
lilliput native resolution? emdzey01 LCD/Display 2 02-15-2005 06:29 PM
Anyone able to run 800x480 with a Biostar MB + Lilliput 7"? C-speed LCD/Display 4 02-08-2005 06:36 PM
Lilliput 7" @ 800x480 ryguy LCD/Display 6 12-19-2004 08:11 PM
