PLease help me play the matching game!
This is a pinout I got from Datalux for a 10.4" TFT touchscreen, apparently the same connector handles the video and the touchscreen. Can anyone help me identify what means what? I have a Earthvision PCI LCD card with a C&T 65550 chip. I have the data sheet for the card and the 65550. (I also have an SBC with a Silicon IMage SIL154 but that is another matter.
The PCI card data sheet shows the following pinouts on a 50-pin header: P0-P23 (though I note that P15 and P16 are separated by a ground), VDDSAFE 5VDC, +12 Safe, VEESAFE, VDDSAFE 3.3VDC, LP (HSYNC), FLM (VSYNC),SHFCLK, and a bunch of GND. What are VEESAFE and VDDSAFE?
The C&T 65550 chip which is on the PCI card has a "Panel Interface Group" which has the following "pinouts" : P0 through P15 (P16-P23 is on another section of the chip), DGND, IVCC, IGND, SHFCLK, M, LP, FLM, DVCC, HSYNC, VSYNC, DGND, ENAVDD, ENAVEE.
Below is the pinout for the display - is it as simple as hooking up po to po, FLM to FLM, etc.? Whats ACDCLK? Which ones do you think belong to the touchscreen part? Thanks again.
4OP Header(at monitor)->Signal Name At Interface Board
01 GND
02 +12V
03 NC
04 +12V
05 GND
06 -12V
07 GND
08 -12V
09 GND
10 +5V
11 GND
12 +5V
13 GND
24 PNL6/DL1
25 PNL14
28 PNL4/DL3
29 PNL12
16 PNL2/DU1
17 PNL10
20 PNL0/DU3
21 PNL8
22 PNL7/DL0
23 PNL15
26 PNL5/DL2
27 PNL13
14 PNL3/DU0
15 PNL11
18 PNL1/DU2
19 PNL9
30 ACDCLK
31 GND
32 SHFCLK/CP
33 GND
34 FLM
35 FPEN
36 LP
37 NC
38 NC
39 NC
40 NC
