The MP3car.com Store
Thread Tools Display Modes
Old 01-04-2006, 05:09 PM   #16
Heckle0's Avatar
Vehicle: Pontiac Grand Am 2003
My Photos: (0)
I've been wasting my time with this issue. Should have done this search here long ago. Thanks for the info. I'm nervous about wiring from my pc psu to the xenarc. Is there anything i should be careful of?
Another Novice?
Progress so far <-------*-> 88%
Kenwood MPV5025 with Aux
Via MII10000
512MB Ram
LG Slim DVD\CDRW
Xenarc 700TS
M1ATX
Pharos GPS
SYBA USB2.0 4-port Hub
Bufalo 54Mbs Wirelessb/g PCMCIA card
Heckle0 is offline   Reply With Quote
Sponsored Links
Old 05-29-2007, 03:06 PM   #17
wizz's CarPC Specs
wizz's Avatar
Vehicle: 03 Focus Zetec
My Photos: (0)
Same Noise Problem
Sorry to resurrect this Guy's but I'm having the strobing horizontal lines problem too, despite trying all the fixes in this thread. These lines do disappear at times but return randomly for no reason I can figure out.
I have a LinITX Plus touchscreen and a MiniItx carpc with P4 mobo and M2-ATX PSU. I use a ground loop isolator so no sound interference problems, just video.
I have tried the following:-
8 gauge grounding all round (solved a grounding interference issue, but not the horizontal lines)
Made a common ground for PC & screen ( still lines )
Powered the screen via the M2 ATX ( still lines )
Powered the screen via supplied mains adapter ( still lines )
Set the screen to 75 hertz ( thinner lines !!! )
Re-routed cables ( still lines )
I can't replace the VGA cable because on this screen it's an "all in one" solution, where it joins other cables (T/S, power, RCA inputs etc) in a moulding and bespoke connector. ( ie. one composite cable comes out of the screen)
I guess this is some sort of frequency interference coming down the VGA cable. Can Anyone help me solve this problem
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 05-30-2007, 09:28 AM   #18
JPuma's Avatar
Vehicle: 2001 BMW X5
My Photos: (0)
try powering the pc from another power source other then the battery. I dont know what it will prove as a solution but see if it goes away. I still get video noise on the board monitor when I use it instead of the touchscreen. I solved my problem by powering the touchscreen with the PSU powering the computer.
JPuma is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
A little problem with my car... Maybe... BoyNextDoor Power Supplies 30 11-13-2004 08:58 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 03:51 PM
Media Car not responding... Lilliput problem? carpcnoobie MediaCar 3 09-01-2004 01:38 PM
Beginning to go INSANE!!! *aaaaah* GPS problem t0ffluss GPS 8 12-31-2002 11:37 AM
ugh.. .screen flicker driving me bonkers! help! 00CericaRuss LCD/Display 10 12-11-2002 04:46 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
