Old 08-21-2001, 02:48 PM   #1
Registered User
Post LCD not working (this is different then the normal)
I got a 4x40 lcd,
The first time I hooked it up, only stuff would display on the first two lines,
Then I unsoldered it and hooked it up again, and did it wrong, and ended up applying +5volts to the wrong line (not good, I know)
So I redid it, and it still boots and displays boxes on the first and 3rd lines, but I can't get anything to display, even just using lcdprint in dos.
Any help would be great.
Clarion 200watt head unit w/ Aux in.
Kicker 800watt 4 channel amp
In a 96 Grand Prix SE.
lstrunk is offline   Reply With Quote
Advertisement Sponsored links
Old 08-21-2001, 05:14 PM   #2
peter3's Avatar
Post
What schematic did you use to wire it up?
Peter3
PETER - THE NETHERLANDS - DEVENTER
sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
peter3 is offline   Reply With Quote
Old 08-21-2001, 06:16 PM   #3
Registered User
Post
this one
Old 08-22-2001, 03:26 PM   #4
peter3's Avatar
Post
Well the schematic is oke.
have you tried to adjust the backlight and the contrast. Because mine is just showing bloks on the 1e and 3e line when i set the contrast to dark.
peter3
Old 08-22-2001, 03:29 PM   #5
Post
Istrunk: you probably burned out a controller (or two). I have done that same thing, and while the backlight works fine....controllers won't
Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
pinkysqueaks is offline   Reply With Quote
Old 08-22-2001, 07:21 PM   #6
Registered User
Post
Does that mean I blew the whole lcd?
If so, that really blows, cause I really wanted a 4x40 lcd, escpecially since this one was free ;-)
Old 09-20-2001, 06:52 PM   #7
Post
lstrunk did you ever get that LCD working?
SuperMatty is offline   Reply With Quote
