The MP3car.com Store
Thread Tools Display Modes
Old 04-20-2006, 07:30 AM   #31
Vehicle: 2004 VW Passat TDi Wagon
My Photos: (0)
Post
Great post! I just got my aOpen MiniPC to finally display 800x480 on my Xenarc.
However, when I began playing DVD's or any other MPEG2 files I noticed that DirectX Video Acceleration doesn't seem to be available. Has anyone else noticed this or found a way to enable it? So far I've only tried the PureVideo decoder - I'm going to try DScalar and others after work (though maybe I'll put them on my USB drive and spend lunch in my car .
Thankfully MPEG4 and WM9HD seem to run quite well full screen with smooting and scaling applied correctly so I'm converting any music videos I have to Divx.
I had to install another copy of windows so at boot-up I can choose between the Embedded 800x480 or regular drivers and higher resolutions/DVD. Perhaps I can figure out how to get the driver INF configured so that it's possible to actually change resolutions without modifying the registry/rebooting.
Since I mostly use the PC for music, gps, and sometimes to play music videos I prefer to run at the native 800x480.
amorfeusz is offline   Reply With Quote
Sponsored Links
Old 04-20-2006, 04:05 PM   #32
My Photos: (0)
Angry
please help
at the moment:
Intel(R) 82852/82855 GM/GME Graphics Controller
6.14.10.3943
LCD K301
800x600
where can I find the driver 01/15/2006,5.0.0.756, using 800x480 w 16bit
what I have to do to get 800x480 ?
I tried everything without results.
audijensen is offline   Reply With Quote
Old 04-20-2006, 04:46 PM   #33
My Photos: (0)
now I found and installed this driver
then I wrote the values from backspace and my GUID into the reg-File and executed it
after reboot no effect
I cannot choose 800x480
please help
Old 04-20-2006, 05:23 PM   #34
My Photos: (0)
ok, after a new installation I repeat all the things and now I can choose 800x480,
but the letters not clear
something is wrong, I have to try other values
Old 04-23-2006, 10:42 AM   #35
My Photos: (0)
I was finally able to get DVD's/MPEG2 looking great but for that I have to use Zoom Player. These drivers seem to be really finicky about when they accelerate video.
Also, I figured out how to change resolutions - I now can change from 800x480 to 800x600 or 1024x768. Suffice it to say, I deleted the other windows installation and now am quite happy with this setup.
Basically I just made 2 more entries under the DTD\ registry key (see bold below) and now windows lets me select any of the three at any time. Great for when some pesky dialog window is unusable in native 800x480. You can of course add as many different resolutions as you like - I'm fine with these for now.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\Dtd\1]
"PixelClock"=dword:00009696
"HorzActive"=dword:00000320
"HorzSync"=dword:00000028
"HorzSyncPulse"=dword:00000050
"HorzBorder"=dword:00000000
"HorzBlank"=dword:000000e8
"VertActive"=dword:000001e0
"VertSync"=dword:0000003d
"VertSyncPulse"=dword:00000003
"VertBorder"=dword:00000000
"VertBlank"=dword:0000008e
"HorzSize"=dword:00000019
"VertSize"=dword:00000010
"Flags"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\Dtd\2]
"PixelClock"=dword:00007530
"HorzSync"=dword:00000020
"HorzSyncPulse"=dword:00000078
"HorzBlank"=dword:000000e0
"VertActive"=dword:00000258
"VertSync"=dword:00000003
"VertSyncPulse"=dword:00000002
"VertBlank"=dword:00000018
"VertSize"=dword:00000013
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\Dtd\3]
"PixelClock"=dword:0000fe2a
"HorzActive"=dword:00000400
"HorzSync"=dword:00000088
"VertActive"=dword:00000300
"VertSync"=dword:00000006
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{*****}\0000\Config\1\Port\5\General]
"Rotation"=dword:00000000
"Flip"=dword:00000000
"Edid"=dword:00000000
"EdidNotAvail"=dword:00000004
"PortEnable"=dword:00000001
Old 05-06-2006, 05:39 PM   #36
My Photos: (0)
Hello
i tried this tweak on intel i915GM, and seems not to work
I can't get the 800x480 resolution , i get 720x480 .
My computer doesn't want to reboot , it freezes on parameters saving ( at the end )
Does someone have any idea to fix this ?
Zelos is offline   Reply With Quote
Old 05-09-2006, 11:37 PM   #37
My Photos: (0)
You Are The Man
Quote: Originally Posted by Merzbow
Not sure, I'd suggest playing around with the horizontal settings in PowerStrip to find out. I've discovered that these Intel drivers aren't compatible with hibernate on my machine (blue-screens every time), so I'm back to 800x600.
I just went through your process and it hibernates without any problems.
thanks a lot man, great work!
t.
tiomka is offline   Reply With Quote
Old 07-11-2007, 02:27 PM   #38
vladcarpc's CarPC Specs
vladcarpc's Avatar
Vehicle: Honda Civic EX AT 95
My Photos: (99)
Hello,
I need to translate this powerstrip settings into the driver registry values.
Can you help me identify what powestrip value goes where in these registry values?
PixelClock = Horizontal geometry Pixel clock
HorzActive = Horizontal geometry Active
HorzSync = Horizontal geometry Front porch
HorzSyncPulse = Horizontal geometry Sync width
HorzBorder = ?
HorzBlank = ?
VertActive = Vertical geometry Active
VertSync = Vertical geometry Front porch
VertSyncPulse = Vertical geometry Sync width
VertBorder = ?
VertBlank = ?
HorzSize = ?
VertSize = ?
Flags = ?
Thank you
\/ |_ /\ [)
1995 Civic Sedan EX
CarPC status: [||||||||||||] 100% - Phase 1 Complete!
YouTube video - WorkLog
vladcarpc is offline   Reply With Quote
Old 07-16-2007, 01:59 PM   #39
My Photos: (0)
Holy thread revival Batman!
Comparing the .reg file and Merzbow's screen shot, this is the correlation I see:
HorzBorder = stays zero
VertBorder = stays zero
Flags = stays zero
HorzBlank = (Horizontal Total) minus (Horizontal Active)
VertBlank = (Vertical Total) minus (Vertical Active)
I'm not sure if the Total is calculated automatically by the PowerStrip utility or not - if it's not, I'm not exactly sure how to determine the HorzBlank/VertBlank values.
HorzSize/VertSize: He was able to determine these numbers from the Intel documentation. But if you correlate your desired resolution with the numbers from Intel, you get:
HorzSize
Desired resolution: 800
Intel's matching HorzSize value = 25
800/25 = 32
VertSize
Desired resolution: 480
Intel's matching VertSize value = 16
480/16 = 30
So divide your desired horizontal resolution by 32 to get HorzSize, and divide desired vertical resolution by 30 to get VertSize.
Note: I am not responsible if you damage anything by using the above assumptions to modify advanced timings.
anonim is offline   Reply With Quote
Old 03-24-2008, 03:03 PM   #40
americasfuture2's CarPC Specs
americasfuture2's Avatar
Vehicle: 2008 Chevy Aveo
My Photos: (0)
bumping for my archive and any future pandora owners out there.
i have just now read more thoroughly through this, and it is definatlytly over my head. i am going to need a walk through basically. im running the mp915-b.
Gathering parts----99% (I'll always want something else, its never 100%)
Using and programming in RR 3.14% (I need tons of help on this one!)
First Actual 98 Blazer LT Install
08 Aveo5 SV and 87 Fiero GT needing carputers
americasfuture2 is offline   Reply With Quote
Sponsored Links
Old 05-05-2008, 04:52 AM   #41
Vehicle: Seat Ibiza '02 101hp
My Photos: (0)
Question Interpretation of timings...
Ok i hv CTF-800 (bought from cartft - i live in Greece) and i'm trying to operate the monitor with Intel's 82865G graphics chipset... unfortunatelly, as mentioned, 865 does not support 800x480 resolution, so i'm trying to accomplish that via the hack which was mentioned before...
Looking for the CTF800's timings i found these:
CTF800 timings:
Pixel 33,6
H 37, 8, 43
V 15,3,16
800x480=800,37,8,43,480,15,3,16,33600,278
Generic timing details for 800x480:
HFP=37 HSW=8 HBP=43 kHz=38 VFP=15 VSW=3 VBP=16 Hz=74
VESA detailed timing details:
PClk=33,60 H.Active=800 H.Blank=88 H.Offset=21 HSW=8 V.Active=480 V.Blank=34
V.Offset=15 VSW=3
Linux modeline parameters:
"800x480" 33,600 800 837 845 888 480 495 498 514 -hsync -vsync
which i'm trying to interpet to that .reg file (specificly the bold ones):
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{71F7F719-E874-4707-9A40-55B83F887A1E}\0000\Config\1\Port\5\General]
"EdidNotAvail"=dword:4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Video\{71F7F719-E874-4707-9A40-55B83F887A1E}\0000\Config\1\Port\5\Dtd\1]
; 38550
"PixelClock"=dword:9696
; 800
"HorzActive"=dword:320
; 40
"HorzSync"=dword:28
; 80
"HorzSyncPulse"=dword:50
; 0
; 232
"HorzBlank"=dword:e8
; 480
"VertActive"=dword:1e0
; 61
"VertSync"=dword:3d
; 3
"VertSyncPulse"=dword:3
; 0
; 142
"VertBlank"=dword:8e
; 25
"HorzSize"=dword:19
; 16
"VertSize"=dword:10
; 0
"Flags"=dword:0
I know how to convert decimal to hex, but I cannot match the meaning of the numbers..
So, please somebody help me with the correct match...
Nazx is offline   Reply With Quote
Old 05-06-2008, 12:53 AM   #42
My Photos: (0)
Anybody???
Old 06-30-2008, 11:31 AM   #43
My Photos: (0)
Hello..
Please, can anyone help me translate these timings provided by CarTFT:
CTF800 timings:
Pixel 33,6
H 37, 8, 43
V 15,3,16
V.Offset=15 VSW=3
to these in the .reg file:
HorzBorder = ?
HorzBlank = ?
VertBorder = ?
VertBlank = ?
HorzSize = ?
VertSize = ?
Flags = ?
Old 06-30-2008, 11:40 AM   #44
My Photos: (0)
yes, ding dong......anyone care to help us out? youll get a cookie out of it.
Old 06-30-2008, 12:28 PM   #45
My Photos: (0)
Quote: Originally Posted by Nazx View Post
Hello..
CTF800 timings:
Pixel 33,6
H 37, 8, 43
V 15,3,16
V.Offset=15 VSW=3
HorzBorder = ?
HorzBlank = ?
VertBorder = ?
VertBlank = ?
HorzSize = ?
VertSize = ?
Flags = ?
ok..
I tried to match the quoted timings but i am not sure if they are correct:
PixelClock = Horizontal geometry Pixel clock ---------33600
HorzActive = Horizontal geometry Active ------------800
HorzSync = Horizontal geometry Front porch--------???
HorzSyncPulse = Horizontal geometry Sync width ---8
HorzBorder = ? -----------------------------------------0
HorzBlank = ? -------------------------------------------88
VertActive = Vertical geometry Active ---------------480
VertSync = Vertical geometry Front porch-----------???
VertSyncPulse = Vertical geometry Sync width -----3
VertBorder = ? -----------------------------------------0
VertBlank = ? ------------------------------------------34
HorzSize = ? -------------------------------------------25
VertSize = ? -------------------------------------------16
Flags = ? -----------------------------------------------0
Is these matching correct??
Furthermore i don't know which numbers match with HorzSync and VertSync (Front Porch for PowerStrip), noted above with "???". Please give me your knowledge..
Sponsored Links
vB code is On
Trackbacks are Off
Drivers for a NON touchscreen Lilliput? romeov LCD/Display 6 07-20-2005 04:19 AM
Article: Satellite toll plan to make drivers pay by the mile VanMan69 General MP3Car Discussion 30 06-12-2005 02:05 AM
TouchScreen Drivers & Installation [iG] Input Devices 15 02-17-2005 10:40 PM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 01:16 PM
Via Epia M-900 Video Drivers Not working mattdisaster General Hardware Discussion 2 01-06-2005 10:33 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
