Old 08-24-2001, 02:14 AM   #1
moahdib's Avatar
Post using both lorty's and winlcd plugins at same time
Hey guys check this out...i have both a 6.8 NTSC and a 40X4...
I am running both lorty's and winLCD plugins at same time on 1 40X4 LCD and AVS and X-plugin on the NTSC... pretty cool huh?
how? use a visualizer mix plugin ( it's called ampdeck)...
from Lorty's I only use the winbond temperature to display my system temperature...and the rest is from winLCD which I prefer over lorty's just for visuals.
I zipped up my ini and dll files in case anyone wanna try.
http://www.mp3car.com/usersites/moah...rty+winLCD.zip
here is screenshot of the 40X4 displaying Artist+Title (scrolling if too long), track time elapsed and total, bitrate, case temperature, time and date. Just pick the best features of each plugin and make sure they don't overlap =)
anyway you guys might think im crazy but it's pretty cool what you can do when you can run multiple VIS.
beware... you are gonna need a fast machine for running a bunch of vis plugins at once...
I just redid my sig, i hope it's not too big hehe..what do you guys think?
[ 08-24-2001: Message edited by: moahdib ]
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Advertisement Sponsored links
Old 08-24-2001, 11:36 AM   #2
Registered User
Post
How did you get a 10C CPU temp in your car? Are you blowing AC on it?
BTW, your LCD does look sweet! I havent even implemented a display yet...
1983 BMW 733i
Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
Gathering parts for carplayer v2.0!
Falcon62Travis is offline   Reply With Quote
Old 08-24-2001, 12:43 PM   #3
moahdib's Avatar
Post
It's not 10C per se....it's the difference of the CPU temp minus the case temp... depending on the room temp.
for example if it's 40C outside, case temp is like 42, and CPU is 52... I am not blowing AC air on it "yet" but I might do that once I figure out a way to get ac air to the trunk via some kind of tube....
My TL CarPC ver2
Old 08-25-2001, 01:40 PM   #4
Post
what m/b u suing to get temp readout
it doesnt work with either of my abit m/b which have have temp sensors
PaulzY is offline   Reply With Quote
Old 08-25-2001, 07:33 PM   #5
moahdib's Avatar
Post
lorty's plugin only supports winbond chip. Use MBM5 and it should tell you what kinda sensor you have.
My TL CarPC ver2
Old 08-26-2001, 02:43 PM   #6
Live and Kickin'
Arby's Avatar
Post
Good to see my lcd's are being put to good use
www.arbybean.com
Arby is offline   Reply With Quote
