white screen, then shuts off - Xenarc 700TS
So previously my xenarc 700ts (newer version with black buttons) was working. However, I removed the back casing and disconnected those 2 wires to the capacitor (at least I think thats what it is, it says 32 ohms) so i could glue the back casing to my dash. Now that its glued, I resoldered those two wires and screwed the casing back together. However, when I turn it on, the screen slowly turns completely white, then after about 10 secs it shuts off and the light blinks like its in standby. When I change the input mode, it doesnt show "AV1" or whatever on the screen like it had previously (Theres nothing hooked up to it, but I dont think that would matter). The same goes with changing the volume.
So does this sound like the ribbon cable issue, a problem with my soldering or something different?
As your looking at the capacitor (i think), if you look from where it says 32 ohms, i soldered the black wire on the left and the red on the right. I'm pretty sure that was right but I didnt take a picture or anything to remember.
