Old 09-24-2005, 11:54 AM   #1
JRA
JRA is on a distinguished road
Question 5'' Displays connecting Problem
Hi.
I asked in some other forums but did not get an answer for this.
i have two displays :
Sharp LQ5AW
and a Philips LTE052T-060
the idea was to build a passive cooled little PC
for my car (place is enough :-) )
and connect one or two of this displays to it.
my problem is that i don't get a good signal to it.
my question is : do i have to use a special controller or something else to connect it to my pc or can i get a cheaper version to connect it directly with maybe some ressistors ?
maybe someone knows a good HowTo that could help me.
JRA is offline   Reply With Quote
Advertisement Sponsored links
Old 09-24-2005, 02:25 PM   #2
neon_eddy's Avatar
neon_eddy is on a distinguished road
that panasonic one looks neat, I couldn't find much on the other one.
one thing that I did to get some better quality was I ran svideo out from my card, and then used a converter to convert that to RCA at the end.
you might be able to use the info on using a PSone screen with VGA output. it requires some resistors and PowerStrip (software).
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
neon_eddy is offline   Reply With Quote
Old 09-24-2005, 03:54 PM   #3
JRA
so i have to buy a controller or the PS_One to use my display...
no direct way ?
the description f the Philips Display says stah i have 2 RGB inputs and V-Sync and H-Sync input...
so ... i thought that this should work...
----EDIT
only for my brain :
i do need FIRST Powerstrip to set um my refresh rate and resolution...
if i don't do this ... will i see something on my display if i connected it right ?
Old 09-24-2005, 11:59 PM   #4
neon_eddy's Avatar
yeah you should, it won't be readable .. but color and such..
I use my rca in screen as secondary only anyway.
I know you're knew (at least here) but I'd push you towards a 7" lcd .. they are so clear and the thought of not using a touch system makes me curse repeatedly
Shawn
Old 09-25-2005, 02:43 AM   #5
JRA
hmmm... maybe you are right...
its just i got them for free and wanted to do something with it.
maybe i won'T use them in my car but i still want to connect them
Old 09-25-2005, 10:53 AM   #6
neon_eddy's Avatar
well I could take one off your hands :-) ..
I would use them as secondary video screens, to my understanding they take rca in right? .. RCA can be readable .. just push the font size up in windows.. and use 640x480
linux will allow the 320x240 .. or some where in between.. maybe windows too.
Shawn
Old 09-25-2005, 12:32 PM   #7
JRA
what i wanted to know is :
can i connect my graphic card directly to this screen ?
Old 09-26-2005, 01:34 AM   #8
bobjones931 is on a distinguished road
I believe, on the Phillips monitor at least, that you should be able to connect pins 1,2,3 to Red, Green and Blue and pins 13 and 14 to the h sync and v sync respectively. I found the VGA (computer monitor) pinout here, http://www.bbdsoft.com/video.html. So just run a wire from the correct pin on the computer output to the same pin on the lcd circuict board and it should pop right up. If you want to get fancy, get a cheapo d-sub 15 connector(http://www.radioshack.com/product.as...%5Fid=276-1502) and tidy it all up. Just make sure that all of the wires go to the same input. Hope this helps a little.
techy stuff explained here-
http://www.tkk.fi/Misc/Electronics/c...interface.html
scroll almost to the end
bobjones931 is offline   Reply With Quote
Old 09-26-2005, 03:18 PM   #9
JRA
ok, thanx , i will try this and tell you.
2004 Hummer H2 4 Displays including fold down 23" Plasma Screen 12Vsystems Show off your project 42 05-21-2005 04:58 PM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
Lilliput Powering On/Off problem masch LCD/Display 0 05-09-2004 12:55 PM
12 volt displays welshman LCD/Display 3 08-01-2003 09:54 AM
