Old 09-28-2005, 02:57 PM   #1
civic5zigen is on a distinguished road
SP-716,DWW-700M doesn't power on? HELP
Hi, I got a SP-716,DWW-700M. Connected using PC power supply's 12v and toy around it for 2 hours. Then it no longer powers on, and there is no lights at all. When power is connected, there is a slight buzzing noise and that's it.
I open up the unit to examine and found the following cap to be tear? Juding from the look do you think it is blown? I dont know electronic but what is this thing called and what does it do? Do you think it could be the source of the problem. Interestingly, other similar caps all have label and wording but this one is completed wrapped in black plastic without any label.
Appericate any help on this.
civic5zigen is offline   Reply With Quote
Old 09-28-2005, 04:50 PM   #2
mike-e-mon's Avatar
mike-e-mon is on a distinguished road
The part you pointed out is an inductor "L10". You can use an ohm meter or DMM to measure the resistance, with the power off, it should measure around 0 ohms across it. But it sounds like you have a short some where, which could be caused by most likely a shorted cap. I would send it back for a replacement.
Mike
"Open your eyes, look within. Are you satisfied with the life you're living?"
Bob Marley
mike-e-mon is offline   Reply With Quote
Old 09-28-2005, 11:22 PM   #3
I am going to try to get RMA from seller, if not via paypal dispute. If all failed I guess my only option is to try to fix it myself. I power it up again and I can say that the buzzing sound and smell is indeed coming from that inductor. Anyone know the spec of that inductor and where can I buy it from?
Old 09-30-2005, 12:45 AM   #4
I contacted the manufactor "Shenzhen DelongGhuale Electronic" and they are suprising hlepful, even more so then yuki the ebay seller. They told me that there are some problem with the L10 in these unit (not sure if they meant it is a common problem tho).
They also stated that the specification for the inductance is 100UH.
Can someone point me to a place where I can get such part?
Old 10-01-2005, 03:02 PM   #5
deznuts77 is on a distinguished road
I have a dead unit as well - however there are no visibly bad components in my unit. So does "Shenzhen DelongGhuale Electronic" offer any kind of warranty or out of pocket repair service. btw googling Shenzhen DelongGhuale Electronic yields nothing.
deznuts77 is offline   Reply With Quote
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
Install coming up... but Power questions technopsych Power Supplies 2 04-14-2004 08:16 PM
Opus power supply issue dmazyn Power Supplies 2 10-15-2003 07:32 PM
