OK update on this.
I have two defective Lilliputs.
Quote: Originally Posted by Enforcer
I am on my third,
1. has a similar problem to you in that it is just white no matter what is connected I need to investigate though.
2. used to have multicoloured lines for VGA but then went weird (see below), composite works fine (it's a headrest monitor at present.)
similar to this
I thought I would try and see if I could make a good one.
so I swapped the LCDs around.
(now the white screen issue JCD thought it might be the board on the LCD)
The different faults went with the main boards, not the LCD's.
(so it's not the boards on the LCD's or the LCD's themselves)
I disconnected the cable on the LCD's, so my next trick is going to be to swap the connectors on the board to see if it is the leads.
To be continued. . . . .
