Old 09-28-2005, 10:11 PM   #1
Lilliput losing calibration
I use the Touchpad Configuration tool to calibrate the screen and that works fine for both the 4 point and the 25 point (advanced) calibration tools however shortly after I calibrate the screen it goes out of wack. I touch the screen and it response like a half inch to an inch away. What could be the reason behind this? Is my touchscreen going? If so, is there anyway to fix this?
tmar89 is offline   Reply With Quote
Old 09-29-2005, 08:37 AM   #2
MaleBuffy's Avatar
What is wrong with you people.....this topic has been covered like hundred times in the past week!!!
MaleBuffy is offline   Reply With Quote
Old 09-29-2005, 08:47 AM   #3
I checked the past couple of day's posts and while yes there are SIMILAR topics, this one isn't the same as others. I am not having USB issues, I did not do any wiring. If you read my post, the touchscreen works. It has been ever since I got it 1 1/2 years ago. But all of a sudden I am getting this lose of calibration issue where sometimes a press on the screen will be right and sometimes it will be off by an inch or so.
All I am trying to do here is get some help and don't want to deal with idiots like you who are so QUICK to bash people for posting what they think is a duplicate post. So what? So I posted something that someone else may have posted. And YES, I did a search and I didn't find anything exactly the same as my problem.
So next time you read my question on a post, either reply with something intelligent to say or click BACK and go bother someone else with your meaningless rants.
Old 10-27-2007, 01:45 PM   #4
tbird2340's Avatar
You ever figure this out tmar? I have the same issue. It calibrates perfectly fine and works in RR etc but after a while it is WAAAY off and I have to recalibrate..
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-27-2007, 03:07 PM   #5
It ended up being a dying touch screen. I replaced the touch screen film and it worked fine after that. http://www.digitalww.com/ has reliable ones.
Old 10-27-2007, 07:25 PM   #6
tbird2340's Avatar
:O Oh noes.. That's not what I wanted to hear..
Weird that it works fine but seems to "forget" the calibration until I recalibrate it..
lilliput calibration failed?? nomorspam LCD/Display 8 06-30-2005 10:41 AM
Lilliput often needs calibration cyrix^ LCD/Display 10 06-10-2005 03:53 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Lilliput Touchscreen Calibration - WORKED FINE - Then.... Mrbmw99 LCD/Display 11 11-15-2004 09:30 AM
Lilliput 4-point and 25-point calibration? chris in nh LCD/Display 3 06-20-2004 02:16 AM
