10-02-2005, 10:41 PM
#1
Vehicle: 1984 Mitsubishi Sigma GK GSR
Ordering replacement lilliput ribbon cable
Hi All,
I need a replacement lilliput cable, cause mine is not very good.. I get lots of colorful lines all over the place when I turn my monitor on. I tried wriggling the cable around on the monitor while it was on, and instead found the CCFL inverter voltage across my hand.
Only thing is that I'm in Australia, and postage is gonna be worth about 3 times what the ribbon is.. anyone in oz got a spare cable they could post over to me ASAP, I'd appreciate it muchly.
Also I've been looking at ways to attempt repair on the cable, any suggestions from people who have had to do this sort of thing before?
Cheers,
Tim.
10-03-2005, 04:45 AM
#2
MySQL Error
Vehicle: Pug 306 & BMW 325i
if it is the internal 40 wire ribbon then look for a 40 way FFC cable. Farnell in the UK sell them so you should be able to get one in Oz.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
10-03-2005, 08:00 AM
#3
MySQL Error
Vehicle: 2003/Acura/RSX
and before you order make sure you know which kind you need (same side or opposite side)
10-03-2005, 09:44 AM
#4
MySQL Error
lilliput should be same.
Xenarc is oposite - which i cant get
oh and you want 0.5mm pitch. but check all this before you order.
10-04-2005, 04:50 PM
#5
Confusion Master
Vehicle: 1997 BMW E36 328I
You got a part number on that scouse?
10-04-2005, 05:48 PM
#6
MySQL Error
Farnell: 335-2663 this is a 210mm, 0.5mm pitch, 40 core, same side Flat Flexible cable (FFC).
I am usre they do different lengths in the catologue.
10-05-2005, 04:24 AM
#7
Confusion Master
cheers will check it out.
210mm
21 centimetres.
8 Inches
halved = 4 inches.
10-05-2005, 04:32 AM
#8
MySQL Error
i think that is the right cable. But you cant halve them.
10-05-2005, 04:48 AM
#9
Confusion Master
I know that. But it folds in half to double back on itself in the lilliput.
I was just trying to guage size and fit.
nb pun intended.
10-05-2005, 05:22 AM
#10
MySQL Error
nb pun intended.
1st place 'ribbon' for comedy to that man!
10-05-2005, 05:23 AM
#11
Confusion Master
Damn minimum credit card order is £20.
I only want 1 @ £2.09
hey scouse, do you get a lot of stuff from Farnells?
10-05-2005, 05:36 AM
#12
MySQL Error
negative ghost rider!
I will ask in avionics if they are ordering anything. Will give em the money and pass it over. Might get a couple myself to see if i can shave the insulation off to turn them into xenarc cables!
leave it with me for a couple of days.
10-05-2005, 05:42 AM
#13
Confusion Master
OK mate.
cheers
10-05-2005, 05:56 AM
#14
MySQL Error
or could do a you know what on you know where
I would take a couple. Only need 5 people wanting 2 each.
10-05-2005, 06:27 AM
#15
Confusion Master
I could also buy 10 and sell 9 of them for a fiver each
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
