Old 10-04-2005, 04:43 PM   #1
Question help lilliput usb not working!!!
newbie here, hope you can all help, ive got a lilliput 7" monitor with usb touch, got the monitor working on my laptop but when i install the driver for the touch screen, both the one on the disk and new one from lilliputs web site its not coming up, and the computer is not recognising the usb as a touch screen divice, it just says unknown device, anyone had this trouble? i brought the screen from my mate who had it working but hes had it back and its still not working? how fragile is the ribbon cable between the usb board and the touch pad on the screen? ive had it off and i may have damaged it if its a bit fragile?
pardoe16V is offline   Reply With Quote
Advertisement Sponsored links
Old 10-04-2005, 04:57 PM   #2
MySQL Error
Sonicxtacy02's Avatar
Its probably not the ribbon cable. its either the touch panel or the touchscreen controller. One of both needs replaced. I'm in teh same boat as you.
Old 10-04-2005, 05:08 PM   #3
where can you get one of these from?
on the lilliput touch screen controler, does it run independantly of the 5V from the usb? is it connected in any way to the VGA board and 12V power supply?
Old 10-04-2005, 09:15 PM   #4
mike-e-mon's Avatar
The TS overlay has nothing to do with windows detecting HW to install the drivers. My guess is that it is the USB controler, but just check the cables to be sure.
Mike
"Open your eyes, look within. Are you satisfied with the life you're living?"
Bob Marley
mike-e-mon is offline   Reply With Quote
Old 10-05-2005, 09:18 AM   #5
MySQL Error
order replacements from armen (digitalww.com). Dont ***** about the wait either lol.
Old 10-05-2005, 09:19 AM   #6
MySQL Error
oh yea and the controller is connected to the vga board with a 3 (i think) cable connector. Its bolted to the board as well.
Old 10-05-2005, 02:12 PM   #7
anyone know what these three cables do? see when i brought the screen i just quickly tested it, and the egg PS had the plug cut off and two terminals on the end instead, i thought i had the right wires in the right hand but i didnt!!! lol lot of smoke, two new caps and a sample order for the regulator i got it working and the screen is ok, just wondering if this is what has knackered the usb? it hasnt touched the screen thou
cheers for the help lads
all fitted but its having a wobler!
Old 10-05-2005, 03:02 PM   #8
mike-e-mon's Avatar
A USB cable has four wires, 5V, ground, data- and data+. I've looked at some pictures on the DigitalWW site and there are four wire going in.
http://digitalww.com/Lilliput_to_Ind...iput_open2.jpg
The USB controler should be powered by the USB buss. I would have through that the USB controler would not be affected by reversed power on the DC input, but I could be wrong? You could check the diode on the USB controler, with a DMM, to see if it's gone.
Mike
Bob Marley
Old 10-05-2005, 04:11 PM   #9
MySQL Error
anyway of tellin us which wire is which?
Old 10-05-2005, 04:45 PM   #10
thanks for that pic im guessing that on your photo red is 5v black grn and the white and orange is the datas? is there a compariotor on the usb front so that data + and data - has no preferance to which way its is wired?
Old 10-06-2005, 08:04 AM   #11
mike-e-mon's Avatar
Check out this tread.
http://www.mp3car.com/vbulletin/input-devices/25075-how-i-fixed-my-lilliput-touchscreen-problems.html
Use an USB extension cable, cut off the end, strip the wires back and solder it to the USB controler board. At least this way you'll know it's not the wireing at fault. The cable can be had on Ebay for $4.00.
Mike
Bob Marley
Old 10-07-2005, 03:16 PM   #12
thanks mike e mon, only problem is my usb controller is slightly different to the one on that tread, it doesnt have the white 5 way connector, instead it just good old simple solder pads, and four of them, the rest of the circuit is very simular thou, anyone got the wire connections for this one?
Old 10-08-2005, 02:02 PM   #13
no one?
Old 10-10-2005, 10:51 AM   #14
mike-e-mon's Avatar
The link I posted before shows a five pin connector, however pin 1 is listed N/C "no connect". The pinout should still the same. Check the wiring with a DMM or resistance meter, and using the diagram posted earlier. Measure from the USB plug to the USB controler to determine which wire is 5V, ground, Data + and Data-. Then make sure the wires are connected correctly.
USB PLUG ----- USB CONTROLER
PIN 1 5V ----- PIN 2 (PIN 3 of 5 pin connector)
PIN 2 D- ----- PIN 4 (PIN 5 of 5 pin connector)
PIN 3 D+ ----- PIN 3 (PIN 4 of 5 pin connector)
PIN 4 GND ---- PIN 1 (PIN 2 of 5 pin connector)
I got my information from the following links:
http://www.mp3car.com/vbulletin/showthread.php?t=25075
http://www.usbman.com/Guides/BelkinM...e_assembly.htm
That should be what your looking for, now go have fun.
Mike
Bob Marley
Old 10-10-2005, 02:03 PM   #15
nice one just wanted to confirm it was the same,
USB keyboard not working after Nlite Jackboot WinNT Based 5 07-21-2005 03:29 PM
Rca on Lilliput not working blustreak LCD/Display 1 04-06-2005 07:05 PM
USB keyboard stops working! (zippy) XxAndyxX General Hardware Discussion 7 05-23-2004 04:58 PM
Lilliput not working v1 & v2 darthvinh LCD/Display 14 05-08-2004 04:37 AM
Lilliput Touchscreen not working jjc319 LCD/Display 5 02-01-2004 05:37 PM
