Welp, what happened was, I didn't take the CCFL out when I was trying to lengthen the wires. Hell I was successful in lengthening them.. no issue.. used 3 layers of heat shrink.. was nice.. But the wire on the ccfl was a PITA.. under the rubber insulation it had some plastic insulation.. tough to get to the bare wire.. Apparently I pulled to hard on the one wire (red one) and the bulb cracked where the wire lead goes into the bulb.. I found this out AFTER i took the bulb out.. bleh.
Just sayin, be careful.. if you can, take the bulb out first..
(btw, don't say something weak like you don't know much about ccfl's or scousemonkey will come in and flame ya and get all ****y)
