Old 10-10-2005, 06:41 AM   #1
Blazenhazn's Avatar
Laptop 10.4 pinout
I'm sorry to sound like a complete moron, but i've got a Toshiba 10.4" LCD that i'd like to use and am having a terribly difficult time trying to figure out where to even start. It has a 14 pin connector (d-sub, i guess it's called??) which i assume could be connected directly to a VGA port, when i search 14-pin vga pinout on google, I get these character display pinouts of like:
1 Vss - - Power supply (GND)
2 Vcc - - Power supply (+5V)
3 Vee - - Contrast adjust
4 RS 0/1 I 0 = Instruction input
1 = Data input
5 R/W 0/1 I 0 = Write to LCD module
1 = Read from LCD module
6 E 1, 1->0 I Enable signal
7 DB0 0/1 I/O Data bus line 0 (LSB)
8 DB1 0/1 I/O Data bus line 1
9 DB2 0/1 I/O Data bus line 2
10 DB3 0/1 I/O Data bus line 3
11 DB4 0/1 I/O Data bus line 4
12 DB5 0/1 I/O Data bus line 5
13 DB6 0/1 I/O Data bus line 6
14 DB7 0/1 I/O Data bus line 7 (MSB)
...What is a data bus line? Where are my Red/Green/Blue Ground and Video pins?! And the power inverter ribbon cable that goes to the motherboard makes 4 total connections.. But the ribbon cable is split and i don't even know how to hook a voltmeter up to the remaining cable.. I am just obviously terribly lost, and I would really appreciate it if someone could point me in the right direction
Lexus GS300
Old setup - 10.4 non-touch, Media Center 2005, Biostar M7NCG, AMD Duron 1ghz, M1-ATX
..Moving on to something MORE PRACTICAL :)
Blazenhazn is offline   Reply With Quote
Old 10-10-2005, 07:04 AM   #2
Blazenhazn's Avatar
More importantly, does anyone here know how to solder a freaking ribbon cable back together?
Lexus GS300
Remote laptop startup ambush Laptops, Tablets, UPMCs, etc. 46 06-06-2007 10:55 PM
LG laptop screen pinout? Alphamandal LCD/Display 2 08-30-2005 07:58 AM
Laptop vs desktop wei2cool General Hardware Discussion 17 03-17-2005 06:25 PM
Laptop remote on/off issue -- SOLVED: s2000 carputer skybolt General Hardware Discussion 17 09-20-2004 11:52 PM
10.4 VGA Touch w/ Laptop Rafster LCD/Display 5 06-22-2004 08:09 PM
