Old 10-12-2005, 03:11 PM   #1
Jay2001's Avatar
Unhappy LinITX 7" resolution issues
Hi all, long time no speak.
Well I finally got my LinITX 7" monitor through yesterday and on the whole am impressed. However I am having a slight issue. I appologise if this has come up before but I have searched to forums and can't find it so here goes...
I am using a Shuttle motherboard with onboard VGA controller. Having played with it a bit it is now claiming to be outputting an 800x480 signal which is the quoted native of the screen. Unfortunately (as you can see from the attached photo) the screen seems to think it is getting an 848x480 signal and this is leading to a poor image quality.
Any one come accross this before and have any idea how to fix it?
Jay
Jay2001 is offline   Reply With Quote
Advertisement Sponsored links
Old 10-12-2005, 03:26 PM   #2
Raw Wave
Change the refresh rate under advanced then monitor I think it is - should then display correctly.
Gobby is offline   Reply With Quote
Old 10-12-2005, 03:35 PM   #3
Jay2001's Avatar
60Hz is the only option for this resolution I am afraid, any other ideas?
Old 10-13-2005, 01:40 PM   #4
Tim Lake's Avatar
I have the same issue, anyone got any ideas?
Tim Lake is offline   Reply With Quote
Old 10-13-2005, 03:12 PM   #5
Jay2001's Avatar
OK, some time ago (aout 7 years!) I used to have a bit of software that enabled you to set very odd screen resolutions. I used to use it to set odd resolutions for the MAME emulator if any one cares. Does any one know of some XP software that can do this and I will see what happens if I set it to 848x480 instead of 800x480.
Old 10-13-2005, 03:40 PM   #6
raphizzz's Avatar
did you try PowerStrip ?
raphizzz is offline   Reply With Quote
Old 10-13-2005, 04:46 PM   #7
Jay2001's Avatar
I have downloaded and installed it but can get verry little out of it as almost everything I do with it f****s up the display. Can you suggest what boxes to change values in and what to?
Where can I find a 7" LVDS Display with 800X480 resolution. Maximus LCD/Display 17 08-07-2008 06:35 PM
Lilliput 7" RCA resolution anitanium LCD/Display 15 06-20-2005 08:51 PM
CarTFT's MM400 7" and LinITX 7" same thing? loscooby LCD/Display 8 05-13-2005 12:40 PM
Help solve my resolution problem on my 7" Lilliput!! CDL0012 LCD/Display 0 06-14-2004 11:01 PM
Lilliput 7" VGA and EPIA M9000 issues... heat LCD/Display 9 01-15-2004 03:57 PM
