Old 10-28-2005, 08:18 AM   #1
munkynpunky's Avatar
Question My Lilliput is black and white??
Hey,
2 x Brand New Lilliput 319GL TFT 7" Screens.
1 x NVidea Geforce MX4000 128MB (2xVGA, 1xSVIDEO)
I have a small converter to change the SVIDEO output to a compisite type lead and a then i plug in the single yellow lead from the lilliput screen. The screen shows but it is in black and white, - If i plug the red compisite cable in nothing happens but if i plug the black lead in the AV2 shows the picture but it is also black.
Anyone know how to sort this?
Cheers
Drew
P.S. I did but couldnt find anything.
Car is Dead, Hand is burnt - Let that be a lesson to me! never open the bonnet when you smell burning.
http://www.digital-car.co.uk
munkynpunky is offline   Reply With Quote
Advertisement Sponsored links
Old 10-28-2005, 05:13 PM   #2
Could this be a conversion problem between S-Video out and composite? The screens both do the same but I cannot get through to lilliput...
Old 10-28-2005, 05:26 PM   #3
Raw Wave
Rob Withey's Avatar
Sounds like a PAL/NTSC thing. See if your graphics card has a setting for which one it uses, and switch to the other one.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 10-28-2005, 05:44 PM   #4
sounds like you purchased the 1954 model...
bagwellfive is offline   Reply With Quote
Old 10-29-2005, 05:45 PM   #5
lol.. well i just bought this... http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN%3AIT&rd=1
Hopefully do the trick....
Checked through the NVidia Drivers and cant find anything to specify PAL or otherwise, but my cards are UK and the screen supports PAL or AUTO. On both settings still show black. I'll try this new cable and then may have to by M10000 board with RCA TV Out
Old 10-29-2005, 05:59 PM   #6
Hi Again.
Pal idea is out, Just checked the NVidia site and found out how to check my TV output is PAL UK... and it is, but just incase I went through all the settings including the US ones.... Nothing, they are all B+W..
Spoke to Maplin Electronics today.... They said that quite often S-Video to RCA connectors cannot display colours correctly as you are going from 4 pins to 2 and it will cause an issue. I said well why would they make them if it causes b+w issues?? his answer..... why do they make any *****??? I was like eh!!?? Ok then.....
Good here lol........
Old 11-20-2005, 08:22 AM   #7
*BUMP*
Any ideas as to why i still only have B+W on an RCA?
Thanks in advance
Old 11-20-2005, 09:25 AM   #8
Well, if you want to have color when going from s-video to rca you need to add a small capacitator in your s-video centre line. Add a ca 400pf capacitator in series with the pin 4 chrominance and rca video centre line.., then you will definatly have color.
like this
Y-ground------------------+rca ground
C-ground------------------+rca ground
Y-------------------------+ rca video
C------------||-----------+ rca video
From the land where all the blond hot babes come from. Everyone is named olga and the weird thing is that we all talk with a swizz accent... give it your best guess.
Biograph1001 is offline   Reply With Quote
TV-out only displays video in black & white, black borders on top & bottom, HELP! prospero LCD/Display 11 01-05-2005 12:24 AM
LCD displays black and white on TV-Out SwapMeet LCD/Display 13 12-26-2004 09:49 PM
black line, and black w/ white stripe line... delussional77 General Hardware Discussion 16 06-21-2004 09:37 PM
SV24 only outputs black and white to TFT B3AND1P General Hardware Discussion 8 06-11-2002 09:34 PM
riva tnt2 with tvout black and white on first startup gerard General Hardware Discussion 3 07-26-2001 04:48 PM
