Old 10-31-2005, 11:45 AM   #1
MTSVO-SC question
I've installed the screen and it works except for those flickering lines, I've read and searched alot on this subject but everybody seems to have a different kind of problem.
The flickering goes stronger when the music is playing harder, but the brightness of the screen doesn't dim.
It is installed with the original cables in my DIN opening.(Original connection plug not cut of)
Is the ground good enough here?, I've also tried grounding the case but since it is made out of wood, that wasn't so easy, grounded it at the mounting holes on the motherboard, but it didn't solve the problem.
When I hadn't installed it yet, but tested it all on a battery inside the house it also had the same problem.(So the grounding points where the same)
Connecting the screen to the M1-atx solved the problem, but since it then loses power when the PC shuts down it also loses its settings, so this isn't a viable solution.
Can anybody help me with my problem?
P.S.:Sorry if my english isn't to good.
ocram is offline   Reply With Quote
Old 10-31-2005, 12:19 PM   #2
3onDubs's Avatar
It sounds like a power issue based on your trouble shooting steps....
Try using a 12V DC-DC regulator to keep the clean constant power that the M1-ATX provides without the shutdown problem that you described.
3onDubs is offline   Reply With Quote
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
Complete Newbie Question. DomesticImport Newbie 15 07-07-2005 07:24 PM
eminent domain hits hard to one of the federal judge the passed the ruling. lominono Off Topic 70 07-03-2005 02:23 AM
DVD drive question Pokey Newbie 3 05-11-2004 05:26 PM
lcd power question jrbless LCD/Display 1 04-07-2002 01:27 PM
