I've seen and tried these monitors myself. They are available in Canada (Vancouver)
http://www.jetviewcam.com/25.htm. The resolution is not too bad. It actually is quite comparable to the older liliput except theyre not as bright. The build quality is not as nice...cheap plastic bezel. But then again, depending on application, if you needed to modify and mold the existing bezel it shouldnt be a problem. The ebay posting says up 640x480 but the Canadian site lists it at 1024x768. Note that they also list it with a contrast of 250:1 and 400 brightness - not even close to a xenark ! But you get what you pay for.
