Old 11-03-2005, 11:28 AM   #1
HoSS's Avatar
Touch screen problem in XP
I have a new 700H (non-motorised) screen to replace my Lilliput.
I test installed it on my destop pc no problems.
I then installed it on the car pc, ran the cal software, and it worked without problems.
After the next reboot, the touch screen did not work. If i manually run the cal software (touchkit) it find the screen and it works again until the next reboot.
I have the latest drivers 4.0.2.1929 from here: http://www.cartft.com/support/drivers/TFT
I think that maybe the desktop ran because i used older lilliput drivers, but i dont really want to backstep the drivers beacuse the newer version has some good addtional functions.
Somebody else must had seen this problem, no?
HoSS is offline   Reply With Quote
Old 11-04-2005, 11:05 AM   #2
Is it ran directly to the computer's usb port? If its ran through a hub, it might be a power issue. Hope that helped.
volum3rider is offline   Reply With Quote
Old 11-11-2005, 06:59 AM   #3
HoSS's Avatar
no, its direct to MB.
It seems to be a software/driver issue not power
bump
Old 11-12-2005, 12:09 PM   #4
albysure's Avatar
i had a problem with my touchscreen and my gps receiver. conflict on com 1-they both liked it. now i have a usb receiver that uses a usb to serial emulator that put the receiver on com 3. now all is good
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Old 11-13-2005, 06:53 PM   #5
HoSS's Avatar
Solved it.
After try complete reinstall'sof XP and 5 differnent driver versions..
I found that the 3.2.3.3122 liliput drivers work.
phew
Old 12-14-2005, 08:48 PM   #6
where did u get the 3.2.3.3122 driver?..i cant find it anywhere, i have touch screen problem too, touch screen stop working after 10~15min, i have unplug and replug the usb cable to get the touch screen back to work .....
sd5254942 is offline   Reply With Quote
Old 12-15-2005, 09:07 AM   #7
cyrix^'s Avatar
I've had the same problem, and yes it was a driver issue here also !
sd5254942, they are here..
http://cartft.com/support/drivers/TFT/tftdrivers/
cyrix^ is offline   Reply With Quote
Old 12-15-2005, 10:11 PM   #8
thx man..going try that
Old 12-22-2005, 05:24 AM   #9
touch screen stop working at random time after cal
I recently got the 700H screen from DWW, and experience similar problem with the touch screen. It works right after calibration and then it would unpredictedly stop working. I would cal again then it work and then a few second or minute later it stop - driving me insane.
I did a clean install of window xp and try both 3.2.3.3122 and the latest one, 4.0.2.1929 (clean install prior to each driver install) but the same problem persist.
is there any more driver I can try? am I missing something? Please help!!!
thanks,
98_Prelude is offline   Reply With Quote
Old 12-22-2005, 05:29 AM   #10
believe or not, i fixed it by grounding the computer chassis to car chassis, give that a try ...
Old 12-22-2005, 03:51 PM   #11
the computer case is ground to the car chassis. any more ideas?
Old 12-23-2005, 05:46 AM   #12
if your car engine is off, does the problem still persist?..if no, then..bad grounding...
Old 12-23-2005, 05:50 AM   #13
HoSS's Avatar
sdxxxxx
The problem mentioned in this thread is with drivers not electrical, I suggest if anyone is having electrical problems you make a separate thread rather than spam up this useful 'driver version' solution. thx
Old 12-23-2005, 10:22 AM   #14
sorry for the spam, i wouldnt help him if i know this rule..
Old 12-23-2005, 11:29 AM   #15
simbot41's Avatar
And here is me thinking that he was simply offering a possible solution that more than one member was having. Funny spam comes in all shapes and sizes.
No doubt that what most are describing is a driver issue possibly with com port issues as well. Try testing USB devices on their own to see if they are happy to work.
simbot41 is offline   Reply With Quote
Can't calibrate lilliput touch screen _wd LCD/Display 10 02-14-2007 11:10 PM
Lilliput TOUCH SCREEN StOpS !!!!!!!! vicky_obee LCD/Display 22 01-07-2007 07:37 PM
EBAY: Lilliput 7" touch screen monitor £70 + £6p&p neil77 Classified Archive 0 07-13-2005 06:33 PM
touch screen driver baoser LCD/Display 6 11-25-2004 05:47 PM
Lilliput & Win XP pro !!!! problem vicky_obee LCD/Display 8 07-05-2004 10:12 PM
