Old 11-04-2005, 03:51 PM   #1
kolz is on a distinguished road
700IDT - Tilt question
I know this thing is spring loaded. Can I adjust the degree of the monitor?
kolz is offline   Reply With Quote
Old 11-06-2005, 11:55 AM   #2
LinuxRacr's Avatar
LinuxRacr
I haven't been able to find a way.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Old 11-11-2005, 07:37 PM   #3
Viscouse's Avatar
Viscouse is on a distinguished road
I too am wondering how to tilt it. Even the manual shows how it tilts 15° in either direction, but I can't get it.
Anyone called tech support yet?
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Viscouse is offline   Reply With Quote
Old 08-10-2007, 11:14 AM   #4
Serialk1llr's Avatar
Serialk1llr is on a distinguished road
Holy thread revival batman!
I too am looking to figure this one out, or am I stuck wedging a sock between my dash and the back of the monitor?
Current Rig
Inspiron 5100 Laptop
*2.2 Ghz CPU
*368 MB Ram
*32meg OnBoard Vid
Carnetix 1900 PSU
BU-353 GPS Antenna
iGuidence Nav Software / Mappoint for POI's
Linksys USB WiFi
D-Link USB Bluetooth 2.0
Xenarc 700IDT
Eclipse CD4000 HU
Serialk1llr is offline   Reply With Quote
Old 08-10-2007, 02:30 PM   #5
mike938 is an unknown quantity at this point
The 15 degrees is left/right not forward/back so in order to prop it up forward you would need to wedge something I guess.
mike938 is offline   Reply With Quote
Old 08-10-2007, 05:48 PM   #6
cdcamaro9534's Avatar
cdcamaro9534 is on a distinguished road
Man this thread is 2 years old. GEEEE
If you want to change the tilt of your 700IDT, you could add some rubber to the cushions behind the screen that are used as bump stops against the metal brace. If you want to angle it up, you could remove the bump stops and get a few degrees up.
1995 Chevy Camaro
VIA EPIA M10000 Mini-ITX Motherboard
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
Road Runner Frontend w/ Liquid Smoke's skin
Xenarc 700IDT with DVD CDR/RW
cdcamaro9534 is offline   Reply With Quote
Old 01-27-2009, 01:29 PM   #7
John_Duh's Avatar
John_Duh is on a distinguished road
some threads just won't die ...
I just finished installing the 700idt in my dash and i found it's pointing to the ceiling too much.
When dismanteling the thing i found a stopper with two screws (i know i should have taken a picture)
I tried to move this thing forward, but it blocked the screen tilting mechanism. Has anybody tried bending this thing ?
If i take it out of the dash again i'll take some pics
ok ... just spent some more time looking at this thing. It seems you can easily change the tilt angle of the screen by adding some extra padding to the support and the back of the screen. In my case I added a 1mm thick piece of plastic to the back of the screen and a second 1mm piece to the support.
Any more on the back of the screen and it won't close anymore.
Also be carefull not to block the opening motion of the screen when adding thickness to the support. I only added a 3mm thick strip to the top. Seems to do the trick perfectly without getting in the way of the opening screen.
Hope this helps
'02 Toyota Celica TS
Carputer progress : [#######---]
Currently working on : software ...
Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
Parts needed: USB wifi dongle (with external antenna)
John_Duh is offline   Reply With Quote
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Complete Newbie Question. DomesticImport Newbie 15 07-07-2005 07:24 PM
Quick 700IDT Question ukchris LCD/Display 0 06-13-2005 09:43 PM
Decision time...DWW-700M or 700IDT? taimoor LCD/Display 4 05-19-2005 01:32 PM
DVD drive question Pokey Newbie 3 05-11-2004 05:26 PM
