Laminar, show me a pic of such option.
I have the Lilliput 629 and no where in the hidden screen does it have an option to auto switch source.
I tried the relay idea as though in the first post, but it's unreliable. The reason is because when you back up sometimes you only go into reverse for a couple of seconds and might go back to first gear after such. Well, the signal for the source switch is not so intelligent and has a delay...so you might end up with the rear camera view even though you're out of the reverse gear.
So, what I did was to set the thing manually. I simply soldered to wires to the source button. I then ran these wires to a manual press switch. So, when I want the carpc to go to the reverse camera, I just press the button and vise versa.
I know it's not automatic, but it works and it's more reliable then having a relay.
