This is an update for anyone who comes across this thread while searching for a similar problem.
I ended up purchasing a broken lilliput board from xdjxklusivex and attempting to replace the faulty capacitor. As it turns out, the old one had the specs for the capacitor right on it, it was a 68000 picofarad 125 VAC cap. Looking at the circuit (and I'm glad I did) the capacitors were installed backwards on the older boards, so following the leads to the inverter (big thing to the left of the cap) to determine polarity is important.
After doing this and still no luck I had almost lost hope - but then came across
digital ww's site and saw them selling 1.5Amp fuses for the board. Tested mine for resistance, found infinity- tested the other board I bought and sure enough the fuse was fine. Soldered it on, and it lit right up - worked perfectly!
The fuse in question is located here:
Anyway, hope this helps anyone else in similar circumstances.
SJC
