Old 11-13-2005, 03:17 AM   #1
Banned
RPM_VR4's Avatar
What I want in a Doube-DIN motorized LCD.
How to do a CarPC if you have a double-din? Too often the doube-din is too small for a full PC, and space-wasting with just a flat-LCD on the front of it. I've seen DIN-PCs and DIN-LCDs, but I need more space and like having a bigger computer in the trunk. The problem is wiring everything from the trunk to the cab. I therefore thing a good double-din LCD / secondary case would be an awesome product. Here's my thoughts on such a case:
The monitor would come out of the center and have 4 positions:
1) Closed: The monitor is retracted in to the center displaying the buttons like the DWW-700M does.
2) Open: The monitor comes out of the slot held by two arms (one on each side of the center LCD slot), then spins to face the user at one of 3 angles, then retracts a bit (once the monitor is spun flat, the arms can retract to bring it closer to the face of the unit).
3) Load-Disc: The monitor re-extends (so it can spin), then spins so the light of the LCD illuminates the top half of the double-din unit. A slot-load DVD player at the top of the unit would then eject the DVD/CD.
4) Security: The LCD would spin so that you are looking at the back of it. It would then retract to fully cover the face of the double-din unit. The back of the LCD could say "Security" on it in yellow and have a red flashing LCD.
The bottom half of the unit would have deeply resessed USB slots (so that most normal size flash-keys could be left inserted when the monitor is in security mode). The slot-load DVD on the top would be the slim laptop-sized with a USB-to-SlimCD adapter.
In addition to the slot-load DVD on the top, the space inbetween the LCD and DVD could have a 2 or 4-line character LCD and some buttons for using the CarPC with the touch-screen LCD closed.
This unit should come with VGA, USB, and non-regulated 12V/GND/Ingition input (with all that room, why not include a 12V/5V regulator to power the screen, USB hub, and the DVD-ROM). The Ignition would have to triger a count-down to auto-Security mode the screen and then fully unpower the screen & hub (no dark-current drain). Actually on second though, you should use the PC's USB 5V power as the switch, not Ignition.
A single USB connection to the PC should connect to a powered hub that provides recessed USB ports on the bottom, the Touch-Screen controller, the USB DVD-ROM, and the character-LCD/button interface.
It would be really cool if the button's were just the normal up/down/left/right/enter from a normal USB keyboard. I'm not sure the best way to do a character LCD interface... maybe a USB-to-Parallel Port chip? To really pimp it out, you could add a tempature sensor and maybe some Internal USB slots for things like blue-tooth or WiFi USB dongles. Maybe even an internal HDD with the IDE-to-USB converter too (laptop and/or normal since you already have regulated 12V for the screen).
RPM_VR4 is offline   Reply With Quote
Old 11-13-2005, 03:37 AM   #2
My Village Called
0l33l's Avatar
I don't see the point for point #1... IMO it would make it much more complex than it has to be.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 11-13-2005, 04:14 AM   #3
Banned
RPM_VR4's Avatar
I see what you mean, but for it to spin to both viewable and security the way I want, it would need to be held by two arms, one on either side of the center. Therefore it doesn't really make it any more complex to just have a hole and a 4th position.
Old 11-13-2005, 04:18 AM   #4
My Village Called
0l33l's Avatar
Having the arms retract fully backwards (to hide the LCD like in the DWW-700M) would make it more complex.
GammaControl v2.4
SKINbedder v3
Old 11-13-2005, 06:04 PM   #5
Banned
RPM_VR4's Avatar
Why? It already needs to be able to extend to spin the LCD and contract to hide the face in security mode. It's just making it able to contract a little further.
Old 11-13-2005, 07:40 PM   #6
My Village Called
0l33l's Avatar
Well, that's harder. You don't see the kenwood screens retracting inward. Try drawing up a quick diagram and posting it to give people some idea
GammaControl v2.4
SKINbedder v3
Old 11-13-2005, 08:58 PM   #7
Banned
RPM_VR4's Avatar
What do you mean? The Kenwood screens do retract, they just fold up from the bottom instead of spinning from two center arms like my idea.
I did draw it out on a piece of paper, but I haven't the graphics talent to post something I wouldn't be embarrassed of
Old 11-13-2005, 09:04 PM   #8
-zip-'s Avatar
I want my own personal rocketship but they will never make that either...
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
WTB: Motorized LCD Housing jcdillin Classified Archive 3 07-04-2005 10:25 AM
2003 Civic Coupe LCD in Din? thecolor LCD/Display 4 07-01-2005 12:05 PM
Motorized Door To Cover The Lilliput LCD Xtreme2k2 Input Devices 51 12-17-2004 04:22 AM
Double Din Kit for LCD Mount? Plinkey LCD/Display 3 07-13-2004 11:41 PM
