Old 11-25-2005, 03:47 PM   #1
Farrow099 is on a distinguished road
I must say, I don't recommend trying to extend the cables for a laptop LCD... I tried to extend the 32awg wires on my lifebook b and had NO success! They were too small to crimp, twist, or solder.. Single thread in an insulator!
If you have one that molex makes you are in great shape, but otherwize I wouldn't recommend it.. It may be possible with a pin and some cold solder epoxy, but even at that; It may not hold up very well to the vibration and such in the car.
Farrow099 is offline   Reply With Quote
Old 11-26-2005, 04:51 AM   #2
Banned
Motorcity's Avatar
Motorcity is on a distinguished road
Quote: Originally Posted by KevinACrider
Where can one find these controller boards at? I don't think any of us want to buy 100 identical boards. I need one for an LG LP141X3 LCD screen.
Also, do these boards come with a compositve video input built in? How is the screen powered one the board is connected? I can't find anything on these controller boards except for direct part numbers and prices. No information about that or how they work.
I have controllers to work with your panel. No Composite at this time, just VGA/DVI input.
And, I won't make you buy 100pcs.
Motorcity is offline   Reply With Quote
Old 11-26-2005, 04:55 AM   #3
Banned
Motorcity's Avatar
Quote: Originally Posted by 12Vsystems
What if you are using the VIA MII motherboard with LVDS controller option?
I played with LCD's a little bit a my last job and providing you can assign pins with the LVDS controller couldn't it be plugged directly into the board?
Here is the controller I'm talking about. There is another one for 24bit panels
http://www.logicsupply.com/product_i...roducts_id/420
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
Old 11-26-2005, 05:17 AM   #4
Hey man appreciate the heads up, excellant quote btw!
I'm actually just trying to use it with the lappy it came with! But I had no success extending the wires, though those wires you have look to be the ones i need! Can you get me one of the 14wire harnesses?
Old 11-26-2005, 05:20 AM   #5
Banned
Motorcity's Avatar
does the cable on your laptop use seperate wires, or is it a ribbon style?
Old 11-26-2005, 05:26 AM   #6
Here is a picture of the wire I could not extend, it goes from the motherboard to the rear of the lcd panel. The inverter wires are much larger, say 24awg, and can be extended "easily".
Man if you can get me what I need to use that screen I'll ship my girlfriend out as your sex slave (see picture b), lol... J/K
Picture A
Picture B
Old 11-26-2005, 05:38 AM   #7
I actually bought an 8" ts to use with it already, but I would much prefer to use the stock 10 inch that came with the thing.
~if it helps this is a lifebook b 2562
Old 11-26-2005, 05:40 AM   #8
Banned
Motorcity's Avatar
Picture A
Picture B
Your G/F is cute, but my wife won't let me. Not after the last time I tried to bring home a "friend".............J/K
anyway, I can extend that cable with no problem, or I can send you a length of the cable you need, and you can solder it. The cable I use is specific for LVDS panel use, and is not cheap. I pay close to 5.00 per ft.
I use the Coleman Cold Heat soldering tool for these tiny wires. Works great.
here's a pic of one of my lvds cable prototypes.
Old 11-26-2005, 05:46 AM   #9
You sure? These cables have some kind of green inside insulator and like a single thread conductor...
If you feel you can do it I'll ship the replacement cable I got (to replace the one I ruined) out to you monday morning, haha.
And we can work out non women related payment via paypal, lol.
Old 11-26-2005, 05:46 AM   #10
Banned
Motorcity's Avatar
Forgot the picture.
You don't want to extend the inverter output wires. Those are AC power, and should be kept as short as possible. Instead, extend the input wires.
You can also run the USB lines through the cable I use, that way you avoid a usb cable. Just terminate the one end to fit the touch controller, and the other end with a standard usb connector to plug into your laptop.
Old 11-26-2005, 05:51 AM   #11
~The laptop has built in touchscreen, no usb...
Old 11-26-2005, 05:54 AM   #12
Banned
Motorcity's Avatar
What is the make and model # of the lcd panel?
I want to verify that it is LVDS, and not TTL. Big difference. TTL can only go about 18" in length, whereas the LVDS can go upwards of 15ft without signal loss.
Old 11-26-2005, 05:55 AM   #13
Banned
Motorcity's Avatar
so the touch panel connects directly to the motherboard?
Old 11-26-2005, 11:55 AM   #14
yeah far as i can tell... not sure what the lcd is, its a fujitsu lifebook b 2562... i'll see if i can find a model on the lcd
MUST SELL!! Sharp LQ10DX01 LCD, controller, inverter, cable *CHEAP* mbrandons Classified Archive 3 03-21-2004 10:06 PM
LCD Cable scott011422 LCD/Display 0 03-04-2004 06:33 PM
LCD cable distance lpoht LCD/Display 2 04-07-2003 08:21 PM
Shortening VGA cable to LCD mrandery LCD/Display 1 08-16-2002 05:43 PM
LCD cable won't work dudah85 General Hardware Discussion 13 07-18-2001 10:35 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
