Sweet. I got my 700IDT to fit in the DIN cage. That's 1 battle done. NOW, here's the next challenge.
By design, the front of the monitor needs to stick out about 15mm form the face of your dash, in order to open & tilt. That's not going to work for me since I want the monitor completely inside the dash, hidden from view.
So, the theory goes that it needs to be pushed back 15mm, and the extension mechanism & stop needs to be brought forward 15mm. This is a mini-worklog cause I don't think anyone's done this (that I could find). I'm interested in input as I go along.
Below is an overall pic of the inside from this
thread.
There's a couple of things I'll have to do:
1. determine where the "extended" stop is & move it
2. determine where the "stowed" stop is & move it (I actually know where it is already & how to move it)
3. tighten some of the springs so it will extend more (I have to do this anyway since my DIN slot is at an angle)
4. probably move the power supply PCB since I don't want to stress the ribbon cable
5. possibly extend the slides? This seems like the hardest part to me.
6. don't screw things up so I can't put a DVD drive in the future.
The advantage to #4 is that if I internalize it, I can put the cable connectors inside as well, and then remove the U-shaped bars in the back (no vent holes, so it can be pushed all the way back). This will give me the room I need to push it back.
Wish me luck...
