Old 12-22-2005, 02:13 AM   #1
Installation question
I just bought a double-din installation kit for my 2000 Celica GT. I am going to install a carputer and hook up the audio into the AUX-IN of my head unit. Excuse my ignorance, but the double-din has one regular slot and a much smaller slot with a pocket. Will the in-dash TFTs go into the smaller slot? Am I missing something? It appears that I have to have the pocket in because the mounting brackets hook into it. I've tried a bit of searching, but I'm new to this forum and my search couldn't find it.
aclockkworkoi is offline   Reply With Quote
Old 12-22-2005, 07:27 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
Double-DIN means two DIN spaces.
Don't use the installation kit. The two single-DIN units will fit in the space on top of each other.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 12-22-2005, 04:23 PM   #3
Now I'm even more confused....
Old 12-22-2005, 04:26 PM   #4
There are very narrow indash monitors that go in a 1/2 din space, but they are few and far between. Most ALL of them are a full din size. If you have a double din space you can put in two din units of whatever you want. Still confused?
mac_smitty is offline   Reply With Quote
Old 12-22-2005, 04:43 PM   #5
Daley's Avatar
Toyota's typically have a DIN-sized HU and a DIN-sized pocket below, resulting in a double-din opening. Both of these units bolt to silver brackets (one on each side) which bolt to the dash. If you intend to keep an existing HU and aux-in to it, you'll want something that can replace that din-sized pocket below. Many options are available, just look around. Hope this helps.
To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
If it's not fun, you're not doing it right!
Daley is offline   Reply With Quote
Old 12-23-2005, 04:25 AM   #6
Thanks....it does. I am replacing the original CD player with my own, and I bought what was supposed to be a double-din kit from Fry's. The hole/pocket below the regular sized hole on this kit is too small for a regular HU to fit into it. It's not near half, just too small. I guess I'll just have to look for another kit. Any suggestions on where to shop for such a kit?
Old 12-23-2005, 09:01 AM   #7
See, that's what you're missing.... You don't need a kit at all. The two single-DIN units will fill up the enter double-DIN space. The whole point of the kit you did putchase was to cover up the gaping hole that is left when you put a single-DIN headunit into a double-DIN space.
The only thing you may want is some sort of trim ring to make the space around the two units look a little nicer.
My Worklog
Old 12-24-2005, 01:01 AM   #8
Ahh ok. But will they be secure? I guess I'll just have to get a screen and find out. I can use the kits trim and just cut out the divider. Thanks a lot guys.
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
Destinator SDK / DLL Installation and Map Installation aseraj Map Monkey 9 03-31-2005 03:40 AM
Where to get power inverters? Other question... aquavita Power Supplies 3 03-27-2005 12:13 PM
Xenarc, installation question.. Mtlca401 LCD/Display 22 05-15-2003 12:09 AM
