Old 12-22-2005, 11:59 AM   #1
shrinkydinx's Avatar
can i hook this monitor directly to my car?
th sticky says:
Quote:
*Powering a 12V rated CCFL inverter off a 12.8V battery could actually cause an output current increase of 5%. This is turn could reduce the life of the CCFL by up to 10%
*A voltage spike on a DC-AC converter can cause flickering and damage to the lamp and inverter
...does this apply to this monitor?
http://www.mp3car.com/store/product_...roducts_id=120
shrinkydinx is offline   Reply With Quote
Old 12-22-2005, 12:18 PM   #2
Raw Wave
EsKALad's Avatar
Operating voltage: 10.5 to 14V DC
i got dat ***** sittin on 22s! SUPERMAN EDITION!
EsKALad is offline   Reply With Quote
Old 12-22-2005, 12:43 PM   #3
and cars go from lik 8-17
Old 12-22-2005, 05:00 PM   #4
Banned
Motorcity's Avatar
if your car's voltage is spiking from 8 to 17 volts, you have problems. At no point during vehicle operation should your charging system EVER produce more than 14 volts. When your battery is low, say after cranking or even a dead battery running from say a jump start, your alternator will go full field and supply maximum voltage to your battery and electrical system. This will be 13.8 volts, +/- .2v.
Motorcity is offline   Reply With Quote
Old 12-22-2005, 05:01 PM   #5
Banned
Motorcity's Avatar
th sticky says:
no. the inverter is powered from regulated voltage off the lcd controller inside the monitor. It will receive constant 12v.
Employee Discounted Cars: Flatout BIG LIE! sdashiki Off Topic 33 10-31-2005 06:53 PM
Car as Daemon thecapitalizt Linux 1 08-01-2005 11:27 PM
FAQ: Attention Newbies! The quickest way to learn about Car PC's Bugbyte The FAQ Emporium 2 06-19-2005 04:18 AM
Hook up desktop dc drive to car muldrick General Hardware Discussion 14 12-31-2004 04:52 PM
Looking to buy a car specifically for installing a tochscreen. Need suggestions! sofakng General Hardware Discussion 17 11-30-2004 08:12 PM
