Old 12-22-2005, 01:00 PM   #1
Unhappy New install problems !HELP please!
Hi all,
have done a quick search but didn't come up with anything like my problem, i have just installed my stuff in the car ( a SUPER vga touchscreen monitor, VIA Epia MII 10000 & M1 ATX PSU) this all worked fine in the house while i was setting up (without the PSU) then after i connected the PSU up in the car the the screen goes blurry and the sound will only come out of the left channel.
BTW the screen does not run off the PSU but the OSD on the screen is not blurry it is only XP so i am assuming that this also has something to do with the PC.
This has just put a big downer in my 6 month long project so any help will be greatly appreciated as i am almost at the end of patience with the whole thing.
benzsupra is offline   Reply With Quote
Advertisement Sponsored links
Old 12-22-2005, 05:00 PM   #2
MySQL Error
MatrixPC's Avatar
Double check all connectors and try to run the screen with the wall adapter to see if it is still blurry. The screen is best if it is power by a clean 12V source (12V line of the PSU).
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 12-22-2005, 06:33 PM   #3
kirbycope's Avatar
You probably have more than 1.21 jigowatts of power, check your flux capacitor.
Post Whore's tip:
User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
kirbycope is offline   Reply With Quote
Old 12-23-2005, 09:56 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
Let's see....
For the blurriness: Check the resolution in the Windows display properties. You may be sending a resolution/refresh rate combination that the screen doesn't like.
For the audio issue: If you're sending audio to the SUPER screen, I believe it is only mono audio (assuming it's the same model I'm thinking of). It would help if we knew what model of screen you're using and if you're even running audio intot he screen or into a headunit or amplifier.
Also, some 1/8" cables are NOT stereo. I don't know if that's something that may be coming into play here or not.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
2005 Scion Xb Install fixerofallthing Worklogs 28 03-07-2008 07:09 PM
Problems with new install galant Map Monkey 4 05-20-2005 01:32 PM
Software install problems Bugbyte General MP3Car Discussion 7 05-01-2005 03:40 PM
DLink DSB-R100 Install Problems paiged General Hardware Discussion 12 07-20-2004 06:56 PM
