*SIGH*
First off, let me preface this by saying that you REALLY should not be undertaking a project like this if you don't know how to add/remove hardware from Windows. That's just my opinion.
1) Boot into safe mode. At the POST screen, press F8 repeatedly until you get a menu of boot options, and select SAFE MODE.
2) Go into the Device Manager : Start > Control Panel > System > Hardware tab > Device Manager button
3) Locate the device you want to remove and double-click on it to see the properties. Go to the Driver tab and the Driver Details button. Make a note of all the files listed.
4) Close the properties page and delete the device from the device manager.
5) Delete all the files that you made a note of in step 3. Delete them from the Recycle Bin, as well.
6) Reboot the PC.
If this doesn't work, then you'll need to do some registry editing. If you don't know how to properly remove drivers, I'm not about to tell you how to hack your registry and be liable for your Windows being rendered inoperable.
My Worklog
