Old 12-26-2005, 06:51 AM   #1
SirNemesis is on a distinguished road
Lilliput 7" (629) problems
Hi,
I have a Lilliput 7" touchscreen (629 model, 2005) and it recently decided it wanted to die. The monitor now does not display any picture. The buttons light up normally, but nothing is displayed on the LCD. This includes the menu, and the green text which would indicate source.
My question is, has anyone here ever experienced a problem like this and know how to fix it? Or, does someone here have a schematic for this monitor so I can attempt to fix it, or have it fixed professionally for me?
Any help would be greatly appreciated.
SirNemesis is offline   Reply With Quote
Old 12-26-2005, 01:27 PM   #2
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Quote: Originally Posted by SirNemesis
Hi,
have you opened the case (before it died)?
antimatter is offline   Reply With Quote
Old 12-26-2005, 07:47 PM   #3
Unfortunately I have. It was removed from the case to test fit in my car, then put back in the case and tested. It was working corrected for about 2 hours, then I disconnected it and didn't touch it again for about a week. When I plugged it in again, nothing displayed on the screen.
This monitor has only been used for about 8 hours total, and I have no idea what killed it.
Alpine CDA-7998R & PXA-H700
Diamond D7152 : Infinity PERFECT 6.1
Phass AP4.65i : A/D/S Classic 315i
Caliber CA2000D+ : RE XXX 12"
Lilliput 7" Touchscreen
EPIA SP-13000
512mb Seitec DDR400
80GB Samsung 2.5"
HDA X-Mystique 7.1 Gold
Morex 80w PSU
Old 01-02-2006, 01:56 PM   #4
AngryMan's Avatar
AngryMan is on a distinguished road
this is a pretty common problem!
the 'wireing' inside the lilliput screens is Very fragile.
these are plastic "ribbon" cables with the wiring itself actually printed onto the plastic with a conductive material. it is very easy to scratch this stuff, wich destroys the cable and requires a replacement.
Thankfully, what is much more often the case, is that the problem actually occurs at the point that the ribbon cable actually connects to the components inside. sometimes when these cables get bumped, jostled, pulled etc.. they move a little in the connector and lose proper contact of all the many tiny pins inside.
these connectors are Very BRITTLE, and extremely delicate so you MUST exercise caution when manipulating them.
that being said, try checking all of these connections for a proper fit, and you may want to reseat them on at a time until you can get your unit to behave as intended..
GOOD LUCK.
AngryMan is offline   Reply With Quote
Old 01-02-2006, 08:38 PM   #5
Yes i thought thats what the problem would be aswell. However it is not. I have checked every pin on the cables with a multimeter to confirm nothing is broken. I have also confirmed that they are making contact in the plugs correctly.
The problem with this monitor is much more complicated then that. Thanks for the suggestion though.
EPIA SP-13000
512mb Seitec DDR400
80GB Samsung 2.5"
Morex 80w PSU
Old 01-02-2006, 08:48 PM   #6
Fusion Brain Creator
greenman100 is on a distinguished road
is the screen white or black?
greenman100 is offline   Reply With Quote
Old 01-02-2006, 11:38 PM   #7
AngryMan's Avatar
I took some time today and spliced that cable like I said I would.
surprised that it went in without a hitch but I still cant do 800x480..
Lilliput 7" (first model) touch function dead holistic LCD/Display 3 09-28-2005 02:27 AM
Lilliput Touchscreen Problems Gavc LCD/Display 6 06-27-2005 09:41 PM
FS: 7" Lilliput w/ TS and CNX-P1260 brandon Classified Archive 15 09-19-2004 11:39 PM
FS: 7" Lilliput Touchscreen VGA Monitor : Broken jaeger Classified Archive 12 08-21-2004 08:46 AM
Lilliput problems (yet some more) samc LCD/Display 7 05-06-2004 10:51 AM
