Old 12-29-2005, 11:41 AM   #1
heuninck is on a distinguished road
No image on Lilliput
Hello
First of all my system specs
Lilliput 629 with 15ft extension cable
Via Epia SP 13000
512 Mb DDR Ram
Maxtor 120 Gb (formatted)
Belkin 125 Mbps wifi card
USB 2.0 Hub
Opus 120w
Here is the problem
I connected everything and powered the hub and the lilliput of the opus. When i start the computer everything gets power incl the lilliput but when i push the power button on the lilliput i first get vga signal and after that a little box with no vga signal when i directly on the mobo it's the same. with the tft from inside the house i get the same. Pretty ****ty because i can't see the boot screen and install windows on the disc
Anyone with ideas
Tnx a lot
heuninck is offline   Reply With Quote
Old 12-29-2005, 02:27 PM   #2
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
bad vga output?
xdjxklusivex is offline   Reply With Quote
Old 12-29-2005, 03:59 PM   #3
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
have you tried different memory? have you tried a normal PSU? Try running just the motherboard without any drives attached, maybe you have the HD cable on backwards. Also check the cmos clear jumper to make sure it's not set to clear.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Lilliput no image linzhang LCD/Display 6 11-02-2004 09:02 AM
not a good image on my lilliput mmoeha LCD/Display 0 07-05-2004 05:25 PM
Lilliput reverse image? CDesigns LCD/Display 2 05-13-2004 02:14 AM
Lilliput mirror image feature. Dluvr22 LCD/Display 1 03-09-2004 05:42 AM
lilliput problem-no image. sham LCD/Display 5 01-14-2004 01:13 PM
