Old 12-31-2005, 05:21 PM   #1
chargin is on a distinguished road
What happened to the LCD backlight upgrade thread?
Sorry if I missed it but the old thread died quite a while ago and a new thread was referred to but Ive never been able to find it... Any help appreciated.
chargin is offline   Reply With Quote
Old 12-31-2005, 07:18 PM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Scouse!
Calling Scouse!!!
I'm sure he'll be here soon.
Enforcer is offline   Reply With Quote
Old 01-01-2006, 08:39 AM   #3
coucouillu's Avatar
coucouillu is an unknown quantity at this point
I was waiting for new backlight upgrade too but never arrived. So I started to try some SMD LED solutions.
Some Pics :
Could see the rest here :
Lilliput Backlight Upgrade
But haven't much more time to continue.
coucouillu is offline   Reply With Quote
Old 01-23-2006, 02:09 PM   #4
Dirk9N's Avatar
Dirk9N is on a distinguished road
have the same Problem, searched a new thread, but didn't finde on
Dirk9N is offline   Reply With Quote
Old 01-23-2006, 02:22 PM   #5
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Well i know Jcdillin is working on two projects, The whole upgrade including the tubes is on hold because of sourcing problems.
The inverter upgrade however is being activly worked on. The is what he is using right now and it is sunlight readable. JCDillin has been sourcing and testing different inverters that support PWM. The thought is to use two sources to change the brightness, 1 button (similar to the lilliput except have more bightness levels) or an photocell that will read the brightness and adjust automatically.
Keep an eye out for a thread detailing this soon.
All the credit goes to JCDillin on this one
antimatter is offline   Reply With Quote
Old 03-19-2006, 04:31 PM   #6
Arathranar is on a distinguished road
An invertor upgrade will kill the backlight pretty quickly. A ccfl has a half life in terms of brightness. Upgrading the invertor lets you drive it brighter but it also reduce the half life. Since you can realistically expect 2-3 years of life if you are lucky (I got 9 months from my lilliput before the brightness had dropped very noticably), driving it harder with a more powerful invertor means you reduce that - usually by quite a bit. I really don't want to have a solution that involves replacing my ccfls every 6 months.
Arathranar is offline   Reply With Quote
Old 03-20-2006, 05:52 AM   #7
Confusion Master
Enforcer's Avatar
What's the difference, the lilli's don't usually last longer than that anyway
Old 03-20-2006, 06:05 AM   #8
Dirk9N's Avatar
thats right me 5 lilli's last about 4 weeks (each)
my xenarc now runs since 8 month without any error or fault.
and there I won't risk to burn my ccfl
Old 03-20-2006, 07:05 AM   #9
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
I ran mine for 10 months without any reduction in brightnes. So I really dont see how the stock inverter/lamp combos are getting dimmer after just 9 months, maybe faulty parts or crappy tubes. But I have ran my overdriven tube now for over 10 months and it's still just as bright as when I first started with it. So even if for some reason it decides to get dim here in the next few months i'll just slap another LCD in and go to town. Even if I replace it every year thats only a $100 a year for a LCD panel ($100 is a rough estimate, most I have been able to get for less than $50). So after 5 years i'll end up costing about the same as the LED backlights, just without the heat and all at once expense.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 03-20-2006, 01:41 PM   #10
Well, since my CCFL is already toast. I may as well experiment - how did you upgrade your invertor?
It's not just the frequent upgrades - it's the hassle of having to take apart the dash in order to replace bits of the monitor and the risk of breaking the monitor each time and being without your screen until you get a replacement.
Old 03-20-2006, 07:43 PM   #11
MySQL Error
jcdillin's Avatar
i'll get you the mouser part number that I used
肚子笑痛了
S60 Install
What happened to the CHeck this *** thread??? cdevelasco Off Topic 83 05-18-2005 11:30 PM
What happened to the dscustoms / Xenarc VGA LCD gizmomkr LCD/Display 1 03-31-2004 04:14 PM
Creating backlight for Projector LCD e_fractal LCD/Display 7 08-14-2003 02:02 PM
where to get cheap EL foil for Char LCD backlight? felix99 LCD/Display 4 10-08-2002 08:49 PM
LCD backlight problem UltraMan LCD/Display 3 11-10-2001 10:54 PM
