Hardware:
VIA EPIA M1000 (Using onboard video)
Xenarc 700TSV 7"
15’ VGA Cable (thought it was very high quality…maybe not?) You can see exact model and specs of VGA cable here:
http://www.computerbrain.com/applica....asp?sku=28003
Good news:
Got my carpc in the car tonight Still lots to work on but went in pretty smooth!
Bad news:
Only problems came when I was testing a DVD. It played fine, but the picture isn’t DVD quality. The dark colors look kind of shadowy and almost metallic (little bit hard to explain). Though the picture is pretty good, and when there are no dark spots in a frame you can’t tell anything is wrong, but when you do get a dark scene it has enough distortion in the color to be quite bothersome.
Applications seem to look normal (though most all applications are bright happy colors).
To try to find out if the problem was related to my DVD player or the onboard graphics card I hooked my laptop up to the 15’ VGA cable and got the same thing. Desktop and everything looks great, movie still has that metallic/too dark look.
If it matters I have the same DVD program on both my laptop and the carputer it’s an old old version of WinDVD (v2.3 I think). So I don’t know if there is any chance that could be an issue or not? (Though DVD's on my laptop screen look fine)
Thoughts? I was under the impression that VGA was suppose to be good to about 20 feet? Would you initially assume that the long VGA cable is causing the DVD problems?
Tomorrow I’m going to try some more troubleshooting, but wondered if anyone could recognize these symptoms right of the bat or had experienced something similar.
Thanks for the help!
